20 Most Recent LG 32LC7D Television Questions & Answers
2answers
I have a 32lc7d tv
This problems ur tv are having are only can be causes by two boards,the tv power supply board or the tv Tuner signal board.The tv power supply board that the board where the power a/c cord plug into it.The tv Tuner signal board that the board where the incomming broadcasting signal wire plug into it.This problems very easy to fix.If it is the tv power supply board is the causes,because u can check the tv power supply board carefully u will find dying capacitors parts that will bulging up or puffing up on to it tops.U have all the tools and know basic electronic just replaced all the dying capactors for all new capcitors parts same micro ferit but the capacitors voltages like 5 or 10 voltages higher for better heat resistance for the life of the tv power supply board.If it is the tv Tuner signal board,very hard fix and determine where the dying parts are in this board,because this board is cover with many ICS chips on this board.If the tv the Tuner signal board is the problems best just buy the whole refurbish tv Tuner signal board for the replacement.Or u can tries websites like Shopjimmy.com,Ebay.com to buy the whole refurbish tv power supply board too,if u don't know how to or have all the tools to replaced those dying capacitors parts and also can buy the whole refurbish tv Tuner signal in these two websites too.
7/6/2017 7:45:19 AM • LG 32LC7D... • Answered on Jul 06, 2017
0answers
My LG LCD TV Model no.32LC7D has blocks of colour on the screen when there is motion. If in a still situation as in a DVD menu, the picture is fine. I have a picture but not sure how I can attach?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
5/16/2016 6:52:41 PM • LG 32LC7D... • Answered on May 16, 2016
3answers
TV Changing Channels on It's Own
Are you changing channels with the remote? Try taking the battery out of the remote, its buttons might just be getting stuck? If, when changing the channel by hand, it persists, then it is an electrical problem, and you should contact LG to see about getting your unit replaced.
11/14/2015 10:39:37 PM • LG 32LC7D... • Answered on Nov 14, 2015
LG 32" TV remote function fails to work intermittently. Works by using buttons on side. LG's remote for sound and DirecTV's remote for turning on station tuning. Batteries new in both remotes.
Try looking for the remote sensor. It should look a little like a camera lens or little red tinted window. If you cannot find it just give the entire front of the TV a good cleaning. Finger prints and dust build up can interfere with the signals. Do the same for your direct TV box.
6/4/2015 10:36:18 PM • LG 32LC7D... • Answered on Jun 04, 2015
321C7D black screen
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
3/18/2015 2:29:25 PM • LG 32LC7D... • Answered on Mar 18, 2015
2answers
MY 32LC7D tv when shut off takes its time to turn back on but now when i tried to turn it back on the green light constantly blinks and no matter if i unplug it the green light automatically comes bac
Televisions now are equipped with a diagnostic circuit that send a low voltage , low frequency signal throughout your set when you turn it on. This is to detect any problems with the circuitry and protect the good circuits.. It started out with a component that wasn't working properly but finally returned the signal. With continued use the component finally burnt out and now your set is going into standby mode. The blinking Green light is a code X amounts = a certain problem. Look up the make and model on the internet and it will give what 2 blinks, three blinks, etc means.. It could be anywhere in the set but the blinks will pin point to the board more than likely. Probably in your power board and if you are lucky it is just capacitors which you can replace yourself if you are a DIY 'er. Check out their web site and find out what your problem is first. Good luck! Col. Dana Gillespie ''
12/20/2014 1:18:09 PM • LG 32LC7D... • Answered on Dec 20, 2014
manual
2answers
Auto tuner detects no signals
Sounds like the main system control memory IC to this device is faulty. It does not store the programs. Contact any service technician to replace it. Electro help
12/10/2014 4:11:58 PM • LG 32LC7D... • Answered on Dec 10, 2014
D a reset to this set, and check. If it do not help you, the main system control memory IC to this set is faulty, and should he replaced. Contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
12/4/2014 3:29:48 AM • LG 32LC7D... • Answered on Dec 04, 2014
32lg30d tuner does not work but all av inputs are fine
main board replacement, tuners only are usally not available
7/12/2014 2:24:47 PM • LG 32LC7D... • Answered on Jul 12, 2014
0answers
Remote won't work
Change the batteries
5/17/2014 3:40:51 AM • LG 32LC7D... • Answered on May 17, 2014
How to turn on tv in sleep it has red light in front
If TV works well, you can do it by entering its menu settings. Refer its user manual for details. If the set is not switching ON from standby, the main board to it should be troubleshooted. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
5/3/2014 8:11:38 AM • LG 32LC7D... • Answered on May 03, 2014
I have an LG 32lc7d that switches itself on by itself ? Would a factory reset solve the issue? Thx
Is the on time function on? Go to the menu go down to time then across to on time if its on turn it off.
4/1/2014 2:15:18 AM • LG 32LC7D... • Answered on Apr 01, 2014
LG 32LC7D Television Logo
189 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
lg 32 tv remote function fails work
  • Televison & Video
