20 Most Recent Sony BRAVIA KDL-52W3000 52 in. LCD Television Questions & Answers
on your remote press home > system settings > auto start up > then choose home mode instead of demo
Sony BRAVIA... | Answered on Apr 14, 2018
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sony BRAVIA... | Answered on Dec 26, 2017
Go into menu on the tv and look for start up setting and look for tv ratio and change it. The cables should be right. The wii will not change aspect if the tv is not compatable
Sony BRAVIA... | Answered on Oct 21, 2017
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Sony BRAVIA... | Answered on Sep 03, 2015
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Sony BRAVIA... | Answered on Mar 10, 2015
Hate to give you some bad news...But most likely you have a defective screen. You may be lucky and just have a bad T-con board. Which will do the same thing. But, this is a slim chance of it being the issue. As I have had many of these with bad screens. And only 2 were the T-con board which the color was off and pict was darker than normal. It is the board at the top center of the TV.
Sony BRAVIA... | Answered on May 06, 2014
Try a new or known to be good cable.
Try attaching to a different computer.
Prove the monitor will work first.
Sony BRAVIA... | Answered on Mar 28, 2014
Power board in side the tv needs to be repair or replaced
Sony BRAVIA... | Answered on Nov 24, 2013
To reset the tv to factory/ default settings, please follow below procedure.
Turn On the TV, while holding down Up Arrow on the remote control, press Power button on TV, tv will turn itself Off then back On again, release Up Arrow on remote control.
This procedure will reset all settings in tv to default settings.
Problem seems with lcd panel and I'm afraid it does not seems to get solved by resetting tv however try to reset tv by above said procedure.
Thanks.
Sony BRAVIA... | Answered on Nov 18, 2013
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Sony BRAVIA... | Answered on Oct 26, 2013
About which circuit board you are discussing about? Provide more details please. If you wish to get some details about this, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sony BRAVIA... | Answered on Oct 04, 2013
Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
134 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony kdl 46xbr2 when turn powers up
  • Televison & Video
