20 Most Recent
Hitachi Ultravision P50S601 50 in. Plasma HDTV Questions & Answers
Factory reset hitachi tv
To do a factory reset (System reset); you have to enter its service mode option. Like older model TVs, there is no switch marked "Reset"; to latest model sets.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
9/8/2019 8:43:01 PM •
Hitachi...
Answered
on Sep 08, 2019
My hitachi turns on and says no sync no signal
1. Make sure you're computer is properly connected to the monitor.
2. Some monitors have an input switch. Make sure yours is set correctly as it may have changed.
The "signal" your monitor is looking for is sent from your computer.
4/30/2014 6:28:37 PM •
Hitachi...
Answered
on Apr 30, 2014
Wont come on at all no blue light
If there is no blue light and no sound, then power is not making it into the unit. Is there a red light when it is plugged in? Many of these plasmas have a primary power switch located underneath or on the back. Make sure that is turned on. If you receive power, there should be an indicator light showing power is present. If it is just dead, as if unplugged, then either the main switch is off or failed, or the power supply may need service.
4/13/2014 8:46:51 PM •
Hitachi...
Answered
on Apr 13, 2014
My hitachi p50s601 turns on for 1 second and then
3 Blinks means one of the buffer boards is bad. The way to test it is to unhooking one SDR board at a time, and see if half of your screen comes on properly. If the SDR-D board is bad the bottom half of the screen won't come on when you remove the board. Send it out for repair (less expensive then buying a replacement board) or search for a refurbished board. If your non technical provide this info to a service tech and ask for an estimate. Cost will be moderate. Hope this helps you. Jon
4/13/2014 12:52:27 PM •
Hitachi...
Answered
on Apr 13, 2014
No picture but sound ok
There are many reasons for this fault. It is difficult to type in all details here by this window. If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/Timeslide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the
brand name / model
number / IC used, in the search box at the top right of the display window
11/7/2013 1:33:15 PM •
Hitachi...
Answered
on Nov 07, 2013
Tv wont power up
check the power supply look for bulging electrolytic capacitors then replace it with new one.
8/30/2012 2:58:59 AM •
Hitachi...
Answered
on Aug 30, 2012
