20 Most Recent Westinghouse SK-26H520S 26 in. LCD HDTV Questions & Answers
0answers
Television suddenly turns black
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
8/16/2017 3:00:11 PM • Westinghouse... • Answered on Aug 16, 2017
Screen jumping
this problem coming from 2 parts t.con board or the screen take a chance with t.con board or scrap the tv
2/28/2014 11:25:59 PM • Westinghouse... • Answered on Feb 28, 2014
0answers
Screen size
Be the first to answer 2/2/2014 3:08:38 AM • Westinghouse... • Posted on Feb 02, 2014Be the first to answer
Sound keeps cutting off
Check its speakers.
11/12/2012 3:10:27 PM • Westinghouse... • Answered on Nov 12, 2012
Sound but no picture
Show a torch light on the screen and check whether you can see the picture. If yes, the backlight is not getting on. Check whether the backlight has been switched off in the remote menu, if you have that option. Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
7/26/2012 10:52:42 AM • Westinghouse... • Answered on Jul 26, 2012
Westinghouse SK-26H520S no picture sound
The input signal is missing and the blue screen background comes on the screen. Change the input to some other device which you are sure works and see.
7/25/2012 10:12:31 PM • Westinghouse... • Answered on Jul 25, 2012
How do I fix TA-N1590X31 LF power supply
For the most part the power supply for sets is sold---no parts are available---they (all of them) only want to sell replacement boards and not stock tens of thousands of individual parts.
6/18/2012 2:33:41 AM • Westinghouse... • Answered on Jun 18, 2012
When we turn tv on
It may have bad T-CON board or the bad DC feeding it. You need to check the DC voltage feeding it.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
7/14/2011 4:22:11 PM • Westinghouse... • Answered on Jul 14, 2011
Why wont the tv come on and then when it does the
Problem is in either power supply or - my bet - the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this help in solving the problem...
5/6/2011 5:10:01 PM • Westinghouse... • Answered on May 06, 2011
27-inch lcd sk-26H2405 turns off black
It sounds like the Control board inside is burning out. If you don't have a warranty on this TV anymore, you can contact a local TV repair shop, or contact Westinghouse here: http://www.westinghouse.com/cust_service.html I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2/22/2011 12:32:41 AM • Westinghouse... • Answered on Feb 22, 2011
How do you take the subtitles off?
Hello nick... turn on the tv, then you need to use your remote and press the menu button. under the audio options, you will have the CC [close captioned] options. just turn off. It is the closed caption function that inserted the subtitles in the first place. Joe
Thanks for choosing Fixya!
1/30/2011 9:33:21 PM • Westinghouse... • Answered on Jan 30, 2011
A shadow line down the center of the tv
TV needs servicing CERTIFIED TV EXPERT HERE, follow this information I provided 3 long solutions to this issue/s Solution 1 Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com 2 Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution. 3 When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me
1/27/2011 5:09:45 PM • Westinghouse... • Answered on Jan 27, 2011
I need to activate my new tv
hi
do the following.
Installation
1. Insert Batteries into Remote Control
1) Remove the battery cover.
2) Insert two size AAA batteries corresponding to (+) and (-) marks on the battery
compartment.
3. Connect power cables
Connect the power cord to the LCD TV then to a proper AC outlet.
IMPORTANT: The power input voltage for TV is 120Vac, before beginning; make sure
all devices are turned off.
4. Turn Power On
Press the power button on the right side of the LCD TV, or press the power (Red) button
on the remote control.
5. Select input source for the LCD TV using the OSD menu or remote
control direct select buttons
6. If connecting to Antenna, Cable or other RF source on TV inputs:
scan and edit available channels.
7. If connecting to a PC(VGA):
For the best picture quality, set the timing of your computer to 1366 x 768 at 60Hz.
Refer to the graphic card's user guide of your computer to set this timing.
if u need further assistance contact me through fixya .
ok
12/14/2010 8:17:03 AM • Westinghouse... • Answered on Dec 14, 2010
I pressed the menu button on my remote control
go back to the menu and do a channel scan for cable or if you have a cable box connected change to the input the cable box is connected to with the SOURCE or Input button
12/6/2010 8:36:25 AM • Westinghouse... • Answered on Dec 06, 2010
The picture and audio keeps
it could be a combination of things but here is a simple fix
unplug power from both the TV and Cable Box for at least 5 minutes
flip the HDMI cord wait 1 minute plug power cords back in
ENJOY
12/3/2010 5:06:25 AM • Westinghouse... • Answered on Dec 03, 2010
The set is not picking
You need a better UHF antenna?
11/21/2010 12:03:48 PM • Westinghouse... • Answered on Nov 21, 2010
Westinghouse SK-26H520S 26 in. LCD HDTV Logo
52 questions posted
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
wont tv come when
  • Televison & Video
