20 Most Recent
GE 2.4GHz Cordless Bedroom Phone Questions & Answers
I have the GE 2.4GHz
It will give the beep sound because of two reasons when you press the talk button with no dial tone.
1)Battery no charge-Did the in use/charge indicator come on? then battery based problem.
2)Check installation
Battery no charge
1) charge battery for 16 hours.
2) Clean the charging contacts on handset and base with a soft cloth.
3) See solutions for “No dial tone.”
4) Replace the battery the batteries are stone dead use ohm-meter to read the readings if you get change in reading no problem else change it.
Charger may also be some times defecive check if its working.
Check installation
1)Make sure the base power cord is connected to a working electrical outlet.
2)Make sure the telephone line cord is connected to the base unit and the wall phone jack.
3)Connect another phone to the same modular jack; if the second phone doesn’t work, the problem might be with your wiring or local service.
4)The handset may be out of range of the base. Move closer to the base.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
9/9/2010 1:00:28 AM •
GE 2.4GHz...
Answered
on Sep 09, 2010
No dial-tone
Is there dial tone at the jack where you are plugged in?? Are you sure?
Is this a pulse/tone phone? Do you have a pulse or tone line? Have you made the correct setting? Is the RJ-11 connections solid? Have you tried the wire on another phone and proved it is good? Is there a separate power suply for the phone or does it get its power from (a) the radio or (b) from the phone company?
Here are a couple things to check.
thanks for your quesiton at FixYa.com
1/8/2010 3:51:10 AM •
GE 2.4GHz...
Answered
on Jan 08, 2010
How to set alarm for AM station
Once you are in alarm on mode (hold alarm button on left until it changes display and lets you select buzzer/radio/off) Then you can push the set button to select radio station/volume etc.
12/17/2008 9:22:23 PM •
GE 2.4GHz...
Answered
on Dec 17, 2008
How to turn on the alarm and turn it off
To enable the alarm, push and hold either alarm 1 or alarm 2 button on left side of face... eventually it will switch the display and say alarm enabled and you can then push the alarm button to switch between buzzer / radio / off.
12/17/2008 9:21:07 PM •
GE 2.4GHz...
Answered
on Dec 17, 2008
Hand piece has gone bezerk
I had a problem with not being able to dial out... some digits came up as bizarre symbols and it didn't even take all 10 digits before beeping out. What I did to fix the problem was to remove the battery from the phone - actually pull the battery plug out, leave it for a minute then plug it back in. Then the phone started working again. You might want to try this... sort of like a hard reboot of the phone.
12/17/2008 9:19:12 PM •
GE 2.4GHz...
Answered
on Dec 17, 2008
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
