20 Most Recent
Samsung HLS4666WX 46" HDTV Questions & Answers
My tv fell off low shelf on to carpet but doesn't turn on
Double check power cord. If you can borrow a similar power cord and it works wala that was easy. But it may be something more. Owner's manual trouble shooting may help. warranty? email or call Customer service number in owner's manual, Usually they are helpful if your nice.
3/13/2015 9:02:28 AM •
Samsung...
Answered
on Mar 13, 2015
Samsung DLP , had lamp bust and it made a pop
First check the output of your power supply. I've suspect that you haven't enough supply or unregulated one which sense by the processor and then it will automatically shuts off the unit.
Check for open fusible resistor,leaky capacitor,shorted volt regulator ic on the the power supply.
If you haven't an experience to isolate the problem then I've advice you to look for a qualified tech to do the job.
Thanks for using fixya...
1/27/2011 5:03:44 AM •
Samsung...
Answered
on Jan 27, 2011
Tv will come on for about 20-30- seconds than goes
If lamp has not been replaced in last 2-3 years then it sounds lamp problem.
Also if tv does not shut down and sound is ok while picture is not, this is also symptom of weak lamp that need to be replaced.
Hope this info will help you, let me know if you have additional question.
Thanks.
2/10/2010 4:43:04 PM •
Samsung...
Answered
on Feb 10, 2010
IS THERE A WAY I
Hi
Thanks for using FixYa. Please provide me the make and model # of the DVD to provide you the region free codes for it.
Thanks
Rylee
2/8/2010 5:20:56 PM •
Samsung...
Answered
on Feb 08, 2010
Set shuts itself off when cold.
Has the lamp been resently replaced or has the back been removed? The lamp door switch must be in the down poition when the lamp door is put on. Do you hear a hum or buzz? A bad color wheel will cause shut down. Does the large capacitor on the ballast have a domed top. If so replace power supply,ballast and lamp. Is the voltage from power board to ballast below 350volts. If so replace power board. L hope this helps.
12/5/2009 4:02:24 PM •
Samsung...
Answered
on Dec 05, 2009
White spots on screen
Bad light engine, Part is called ASSY Engine P-dlp part number is BP96-01468E and substiute part is BP96-01478F Encompass Parts Distr list everything for your TV But do not have in stock Light Engine right now you can viist their website CK them out also Try UED 1-800-648-6657 and Go to E-Bay look under Electronic Parts you may find one there.
11/30/2009 2:50:06 PM •
Samsung...
Answered
on Nov 30, 2009
