20 Most Recent Toshiba 62HM15 62" Television Questions & Answers
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Toshiba 62HM15... | Answered on Feb 03, 2015
Examine the lamp first to see if shattered inside.
Toshiba 62HM15... | Answered on Apr 23, 2012
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Toshiba 62HM15... | Answered on Mar 19, 2012
Hi, thanks for posting your Question..
You can get a replacement board from repair outlet stores around your area. Most repair stores will have a replacement, or will direct you where you can get..
Also you can check at shopjimmy.com,or even at eBay.com
Good luck..and take care.
Toshiba 62HM15... | Answered on Aug 31, 2011
The 3 blinks is a sign of a bad ballast - the board that powers the bulb. If the tv starts when you jump the relay it means that the ballast hasn't actually failed, just that , during startup, it draws much more power than it should. This happens when the components age - they lose their insulating properties and a lot of the current going thru them is lost/shorted. The first thing you should do is to unplug it from the wall and leave it like that until you fix it - if a capacitor or a transformer from the ballast finally fails it will fry way more than just its board. You need to replace the ballast board, at a cost of around $160. Here's one
http://www.partstore.com/Part/Toshiba/Toshiba/62HM15/Toshiba/Toshiba/23122468/New.aspx
Toshiba 62HM15... | Answered on Nov 21, 2010
Something is wrong with the lamp or its ballast circuit - take it out and take a look at it, it might be burned. If it's ok then the tv must be opened and tested, starting with the ballast board. If you don't know how to do it the it's better to call a repaiman, it's very easy to mess it up even more.
Toshiba 62HM15... | Answered on Aug 10, 2010
I looked up both models and both tv sets have different part numbers so probably not!
techman
Toshiba 62HM15... | Answered on May 04, 2010
If you have not tried to replace the Lamp, that is what I would do. When the Lamps get weak they will cause symptoms like this.
Skyassoc
Toshiba 62HM15... | Answered on Dec 02, 2009
Toshiba 62HM15 62" Television Logo
35 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba dlp
  • Televison & Video
