20 Most Recent
Thetford Norcold N323 1.7-cu ft 3-way Built-in Refrigerator Questions & Answers
I have a Norcold 323
the unit runs on gas(LPG) so the unit is operational
by ac I take it you mean mains power and by dc you mean 12 volts it being a 3 way cooler
you cannot "jump start" a gas system so I am a bit lost with that statement
check the heating element in the unit for continuity as both the mains and 12 volt power only heat and element that boils of the coolant liquid in the system the same as the lpg flame does
it could be a relay problem for the electrical part
Fridge wont get cold with gas
This is worth a try. Disconect the gas and power make sure the pilot light is out. Turn the fidge unside down overnight then unright again. Try it on gas agian. This worth a couple of goes before giving up.
Norcold model n611rp works on
Sounds like the unit may not have enough DC power. See the manual.
http://www.thetford.com/HOME/PARTS/NorcoldIncRefrigerators/GasElectricRefrigerators/322323Series/tabid/472/Default.aspx
