20 Most Recent
SunBriteTV 4600HD TV Questions & Answers
Tv cuts and on
Please provide more details about the problem you faces with this TV.
"no signal" shows up on
You will need solid coax ends and connects. You need very high grade coax union and snap and seal coax BNC connectors for both ends.You also need a RFI filtered surge protector to filter all the AC plugs for the HDMI box. This shoulf fix your problem
11/23/2012 11:53:24 PM •
SunBriteTV...
Answered
on Nov 23, 2012
We had a roach get inside the front protective
You'll have to remove the back cover of the tv. You'll see screws all around the edge of the back cover. Then you'll have to remove all the circuit boards that are inside. once this is done, you'll be able to remove the glass panel and clean the droppings out.
Sunbrite tv 32 " 2 yrs old. Blue light comes on ,
Hello Joe Harlinski,Welcome, and thank you for using FixYa!To answer your question: Your television will have to be checked for bad (cold) soldier joints on the power supply board, as well as bad capacitors and resistors.A local Television Repair Professional should be able to handle this for you. If the board cannot be repaired, it can be replaced for roughly $75.00 to $95.00 plus the labor to install it.Have a great day!
The TV 's blue light
Hello alaws,
Your issue will require some diagnostic from your local TV Repair Shop. In today's market, unless you find a repairman that does this work for a hobby, the cost of the parts and labor is higher than the value of the TV.
It may be in your best interest to research the LCD and LED TVs at your local WalMart/KMart/Best Buy.
Have a great day!
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
