20 Most Recent
Frigidaire FRT8B5E Top Freezer Refrigerator Questions & Answers
Power Problem
You will certainly have to replace the thermostat. Typical problem is once temp. is reached, it takes forever to come on.
This started yesterday...lights in frig
This sounds like your thermostat is bad. You can replace it where the control knob is. There should be two screws to remove it and then you are able to take the part to a supply house and get a new thermostat for the fridge.
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service
https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer
https://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros
https://forum.appliancepartspros.com > posts > t55646...
Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video
https://www.appliancevideo.com > question > refrigera...
Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk
https://hvac-talk.com > vbb > threads > 53155-Frigidai...
Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ...
Domestic Refrigerator Short-Cycling
Dec 4, 2020
Wiring time delay for a short cycling compressor
Jun 23, 2022
Walk-in short cycles
Mar 7, 2021
Walk-in compressor short cycling
Oct 20, 2008
More results from hvac-talk.com
What does E6 code in Frigidaire wine fridge mean? Model FGWC5233TS
The E6 error code on a Frigidaire wine fridge, specifically the model FGWC5233TS, indicates a fault with the upper temperature sensor. When this error code is displayed, it means that the temperature sensor located in the upper portion of the wine fridge is not functioning properly or is experiencing a malfunction.
To troubleshoot and resolve the E6 error code, you can try the following steps:
- Unplug the wine fridge from the power source for a few minutes and then plug it back in. This may reset the error code and resolve any temporary issues.
- Ensure that the wine fridge is properly leveled. Uneven positioning can affect the performance of the temperature sensor. Adjust the feet or placement of the unit to ensure it is level.
- Check for any obstructions or blockages around the upper temperature sensor. Make sure there are no items blocking the sensor or disrupting its operation.
- If the error persists, it is recommended to contact Frigidaire customer support or a qualified appliance technician for further assistance. They can provide specific guidance based on the model and help diagnose and repair the issue with the upper temperature sensor.
