20 Most Recent
Archos 605 Digital Media Player Questions & Answers
I can't play all AVI's on my Archos 605
Yeah you need to go to the archos website and buy the cinema plug in (£14.99) if you want to play all. the only other option is to convert the avi files that you cant play. Also if you want to play any mpeg4 files and quite a few other files with different audio codecs you need the podcast plug in (again £14.99). This is the only way to be able to play everything on your archos without converting the files - it's a bit of a rip off as each set of plugins is specifically downloaded for a product key so you cant even get one from someone else - believe me I have tried for days to get them free!
Hope that helps!
FORGET CODE
Problème d'affichage, demande un code d'erreur 102 104.
L'écran est tout blanc. Vueillez trouver un solutions à ces problème s'il vous plait.
How can I transfer music
connect the Archos into your computer, allow the computer recognize and install it, open the Archos and copy, then paste it into the Archos, eject if from your computer and that's all.
For Archos manuals, visit the link below:
http://www.retrevo.com/support/Archos-605-PDAs-and-Handhelds-manual/id/3115ag100/t/2/
Scroll down the page and click the download button.
I believe the manual should be of great help.
Good luck
My archos 7 boots up ok but then the interface is
i didnt solve the problem,,,, i did a full format of the hard drive and then downloaded the firmware to re install everything but the problem was still there.... i contacted archos who suggested that it had a hardware problem and i would need to send it to them..... as yet im deciding if i want to go for a replacement or a repair, as i have installed the plugons and would loose them on a new machine...
many thanks
Bernard
11/13/2009 12:06:48 PM •
Archos 605...
Answered
on Nov 13, 2009
Mp3 player has no music
I have recently had the same problem. Does anyone have a link or website to the driver which will reset the firmware?
Archos 605 in demo mode
We called tech support and you fix it by doing a reset on the base of the device. We used a paperclip to push the button. Hope this helps!
Mp3 player archos 605
I called tech support - they said it's a problem with the servers on their end and they are working to resolve it.
Recovery update
Go to archos.com and download latest firmware to desktop.
Connect archos via usb cable.
Turn on archos
copy and paste file to archos root folder.
eject and disconnect archos and the update will begin
605 wifi won't start
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
