20 Most Recent
RCA DRC6355N DVD Player/VCR Questions & Answers
No audio from VCR
You might have the RCA audio cables plugged into the "DVD Only" outputs. Move the white cable to "Out" . Leave the Red audo in the "DVD only" audio plug.
I have no remote
Look on the front for manual controls,should have a button said Menu.No,button on the front controls said Menu,than u need a remote to get in the menu sorry.Try website like Remotes.com to buy an exact to the original remote or very close compatible one.
Need a user manual for
Try this page... they say they don't have the particular manual but it may help to unlock
http://www.retrevo.com/samples/RCA-manuals.html
Lock/Unlock DVD player
• To lock player, open tray and press SETUP, 0, 0, 0, 8, 3 (an on-screen message, "Key
Lock On" is displayed).
• To unlock, press SETUP, 0, 0, 0, 8, 3.
This from another RCA manual but may work
Cheers
mickypics71
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
How do I delete or
Interstingly enough I could not find a copy of your manual in the usual sites. Even RCA themselves do not have the manual available online. There timers usually don't vary much when the model numbers are close. Normally you go to the menu that gives you the choices of Clock, Program, Tuning, and Setup. You would choose Program. Then choose the Program that you want to delete and highlight it. At the bottom of the screen you should see a choice that will say "TO ERASE PRESS CLEAR" and "TO EXIT PRESS MENU". You would press CLEAR. The following website will allow you to download a copy of the manual for the DRC6350N. There shouldn't be that much difference between your model and this one.
http://safemanuals.com/314159.php?k=f3d5d811ddc68719f746d29b76c5d3b3&ID=332749&q=RCA%20DRC6350NYou will need the Adobe Acrobat free reader to be able to view and print the manual. If you don't already have it on your computer you can find it at this website:
http://get.adobe.com/reader/If your machine is too different from this model and this manual does not help you please let me know and I will do further research for you. Thank you for allowing us to assist you.
It eats VCR tapes!
have the heads and followers cleaned and adjusted. any electronics shop can help.
I have a RCA DRC6355N
If you have Snow on the menu as well as the picture or video then it seems to be the modulator. If this is the case it is cheaper too change the whole system.
If you find it is just the video's that are snowy then use a DVD & VHS cleaning kit. If there is still an issues buy a new one
Program combo with remote
"Universal" is a joke; they should be called 'multibrand.'
Although their prices are sometimes stiff, they normally have originals for sale:
Remotes
I LOST MY REMOTE TO
Remotes
Drc6355n
Hold power button on remote for 5-7 secs to see if it responds. If that fails, change batteries, and repeat process. If that fails, I would get a new remote from RCA and/or store. If replacement fails, then the remote led sensor in DVD player is bad - most manufacturers repalce the entire player rather than repair such a thing. But it's probably the remote.
Split screen
That is it thank you sooooooo much. I spent three hours flicking buttons and it is a stupid switch on the back!!!!!
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI
copy and paste link for manual
https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them.
Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse .
TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com
Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
