20 Most Recent LG V181 DVD Player/VCR Questions & Answers
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to
try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
LG V181 DVD... | Answered on Dec 06, 2019
I've tried one like this on mine which had the same problem and it workded.
go to this website for your dvd player (you can also search other dvd players on this site) http://www.videohelp.com/dvdhacks?dvdplayer=LG+V181+&hits=50
open draw
press '0' 3 times
press which region (Eg 0 for multi)
press pause
and whola!!!
PLAYABLE CODEC FORMAT
files DIVX3xx - DIVX4xx - DIVX5xx - XVID - MP43 - 31VX
PLAYABLE DivX file -.avi,.mpg,.mpeg
Hi
All American VHS recordings will be in NTSC system. If your player is compactable with NTSC system, you can play the VHS in your system. If it has no NTSC syste, the tape will play, but colour problems and vertical rolling will occur. OK.
Divx compatibility with this player is limited as follows; available resolution size of Divx is under
720x576 pixel - file name Divx subtitle is avail by 56 characters - if number of the screen is over 30/sec the unit may not operate norm - playable Divx file avi,mpg. .mpeg - playable codec format
DIVX3.xx - DIVX4.xx - DIVX5xx -XDIV - MP43 - 31VX - if the video and audio structure of recorded
file is not interleaved, either video or audio is outputted.- if the fie is rec GMC the unit supports only
1 point of the record level - may be helpful!
LG V181 DVD... | Answered on Dec 05, 2019
try that:
  1. Power on (with no disc inserted)
  2. Press PAUSE
  3. Press 3, 1, 4, 1, 5, 9
  4. Enter the desired RC
  5. Press PAUSE
  6. Turn the player off and wait a few seconds
  1. VCD playback
  2. Press PAUSE, 1, 4, 7, 2
  3. Press UP 6 times, '07 00' should appear on the display
  4. Press Program 6, Program 5 ('07 FE' should be displayed)
  5. Press ENTER
  6. Press RETURN
  7. Power off and on again
LG V181 DVD... | Answered on Jul 12, 2013
I had a problem like that before .I thought it was the dvd disc, but it was the laser head. I changed the laser head and all is good now.
But it is not portable.
LG V181 DVD... | Answered on Jan 02, 2013
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
LG V181 DVD... | Answered on Dec 23, 2012
Please check the front open/close button is pushing inside perfectly or not. May be there is gap between the buttons.
LG V181 DVD... | Answered on Jun 21, 2012
LG V181 DVD Player/VCR Logo
70 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
safe mode
  • Televison & Video
