20 Most Recent
HP Deskjet D4260 InkJet Printer Questions & Answers
How do I clear a document stuck in the print que?
If you are on a network and the printer is shared by others, you are only allowed to clear documents you have spooled to the printer. If someone else has a file jammed in the queue, then they (or an administrator) must remove it.
Hi ! When I install
If you connect your hp printer to the computer, it should install the basic drivers available from the Internet, which hopefully will be automatic. If it doesn't install automatically, then you'll have to manually download the correct driver for the hp deskjet d4260 inkjet printer.
In most cases, the printer will be connected physically with a usb cable. One end goes to the back of the printer, and the other goes to the back of the PC.
Good luck on this.
To download hp deskjet D2460
Hello
OK, the link below will direct you to the HP driver support site. Once directed to the download page, you will need to select the operating system you are using. Once the operating system system is selected, you will be able to download the requested driver.
Click
HERE to navigate to the download page.
Feel free to let me know if you need any further assistance.
Kind regards
Andrea
Can not print...jobs are held in queue
go to administrative tools THEN SELECT SERVICES. STOP THE PRINT SPOOLER SERVICE. then see if the item is still in the print queue.. if so delete it .. but I think it'll go away when you stop the service. when it does.. restart the print spooler
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color.
If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
