20 Most Recent
Philips 37PFL5332D 37 in. LCD Television Questions & Answers
My Philips TV 37PFL5332D/37 has the inverter
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
4/2/2017 3:08:52 PM •
Philips...
Answered
on Apr 02, 2017
My TV was working and
Hello
There is something confusing the system control of your TV and it should me resetted. To reset it, just switch OFF your TV with its front panel power control switch, and after that, unplug the TV from the wall socket. Wait for about 5 minutes or so, and the plug it and switch It ON. If this does not work for the first time, give some more time to reset, say about an hour or so, and try. OK.
3/29/2017 8:13:49 AM •
Philips...
Answered
on Mar 29, 2017
My 32in lcd tv
A company in my home town of Stevenage repaired my LCD TV
Omi TV Repair they replaced a broken LCD panels on my 32" Samsung TV for £115.15.
Amie
3/25/2015 1:14:22 AM •
Philips...
Answered
on Mar 25, 2015
Philips 37pfl5332d won't turn on. A blue light comes on and then turns red and blinks 6 times. Can I fix the tv or is it time to buy a new one?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Blinks counts to Philips Brand TVs are not direct' like other brand TVs. The details about how to count the fault blinks to Philips TV models are given in detail.
3/31/2014 12:23:55 PM •
Philips...
Answered
on Mar 31, 2014
Do I need cable to view local news
Yes it is called "DTV" digital television, you will need a tv, the tv must have a digital tuner built in most do now a days, if your tv is older you will need a digital converter box also, you can go down to your local store to find a digital antenna- take it home and try it. the issue with this is you can get all channels perfectly in one room with no problem and in the next room with the same exact equipment you wont get any or very little channels, unlike traditional analog television digital television either works or not, no sketchy picture- best advice is to buy a set up from a store that allows returns and try it, if it don't work try a different antenna, also try moving it around, keep in mind you will interfere with the signal so if it works take a seat in you chair it might interrupt the signal--Good Luck.
3/30/2013 7:24:40 PM •
Philips...
Answered
on Mar 30, 2013
Digital channels have stopped working, only blue screen!
Try resetting the TV:
- Switch on TV and switch to any analogue channel.
- On the TV: Press and hold the MENU button.
- Menu screen will appear on the display.
- Do not release the MENU until the menu screen disappears.
- TV will go blank for about 60 seconds and then display initial set up screen.
- Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
10/5/2012 4:29:14 PM •
Philips...
Answered
on Oct 05, 2012
