20 Most Recent
Samsung SGH-V200 Cellular Phone Questions & Answers
My phone wont charge
check your charger first, if charger is ok then check the charging connector on the phone, clean it with a toothbrush and solvent cleaners.
Swicth not working
power on/off button print is brake now then tell me what can i do to repair it
My phone is blocked. It says
hi, the PUK code is the security code for the sim card and not the phone, so the message your being told is that this sim card is now blocked this happens if the wrong PUK code has been entered more than 10 times.
All you need to do is get a new sim card for the network your phone is locked to or the same network as the sim card that is in the phone now, once you put this new sim card in you should be able to use your phone, if how ever it still asks for a PUK code then all you need to do is call the service provider for that sim card and ask them for the PUK code they will give you this code for free over the phone
so your phone is not locked its just the sim card, it could be locked if the sim card has been not used for 180 days as they get switched of after this long with no use, so putting a new sim card in your phone will solve your problem
Sim Lock
Use this code (with asteriks and pound signs included) to unlock your phone.
Samsung V200, S100, S300 phone unlock : *2767*782257378#
Hope this works, feel free to leave a positive rating for this solution. Thank you for stopping by Fixya!
Samsung sgh v200
search the programme for it on net or send it via infrared or blietooth
TM PUK CODE
ask your service provider, they will give you the code PUK.best of luck!
Free unlock code for sgh-t528gsamsung sgh-t528g
Hapy New Year:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
How to STOP your Samsung Note 9 from constantly pocket dialing
OMG I finally figured out WHY my note 9 was constantly pocket dialing people. I tried so many things. This is what finally fixed it. It is a gesture setting. Open up settings. go to advanced settings then gestures.. Turn off Direct Dial. Direct dial is a setting that makes your phone call someone that you have been texting when you hold the phone to your ear. What happens is when you put the phone in your pocket it thinks you are holding it to your ear.
Insert sim e1220
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
