20 Most Recent Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator Questions & Answers
3answers
Why is my frigidaire frig with code H and 1 flashing on model ffhs2611Lwf?
Good Afternoon Friend, I understand that your Frigidaire refrigerator, model# FFHS2611LWF, is flashing an "H1" code. This is actually stating "HI", as in either the refrigerator or freezer, temperatures are Hi and not at a safe level. First, press any button to stop the alarm and clear the HI temperature. If you are still receiving the alarm, I suggest checking the freezer, to make sure that everything is still frozen, and nothing is defrosting as, well as checking the refrigerator temperatures. If things are defrosting or the temperature is Hi in your refrigerator, I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, Give your freezer 24 hours to stabilize at the default temperatures of 0 degrees for the freezer and 37 degrees for the refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. -Best Regards- WP
1/7/2020 6:22:15 PM • Frigidaire... • Answered on Jan 07, 2020
Ice with Sediments
in the water supply line to but well before the refrigerator fit a ceramic water filter that has a filter so fine that many germs cannot pass through
11/26/2017 11:49:25 PM • Frigidaire... • Answered on Nov 26, 2017
Can you explain error code 4 flashing on the dispay
This is what I have been able to find online for this error code: Frigidaire Refrigerator Error Codes Fault Codes
11/16/2017 4:13:35 PM • Frigidaire... • Answered on Nov 16, 2017
2answers
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
11/5/2017 6:46:05 PM • Frigidaire... • Answered on Nov 05, 2017
0answers
How do I adjust the water fill level for ice cubes
Click Here and go to page 66=> MSD2454GRW some times that will work and sometimes the core needs replaced. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
6/2/2015 2:14:03 PM • Frigidaire... • Answered on Jun 02, 2015
The settings for refriderator is blinking and staying at 4 what does that mean
it is giving an error code.
7/24/2014 2:36:09 AM • Frigidaire... • Answered on Jul 24, 2014
Wha is the Frigidaire FSC23F7DSB warrenty
Good Morning Friend, I understand that you want to know the warranty on your Frigidaire refrigerator, model# FSC23F7DSB. There is a one year warranty, where the manufacturer will pay all costs for repairing or replacing any parts of this appliance which prove to be defective in materials or workmanship. This does exclude original and replacement ice & water filter cartridges (if equipped). Original and replacement cartridges are warranted for 30 days (parts only). There is a second through fifth year warranty on the cabinet liner and sealed system. This means the manufacturer will repair or replace any parts in the cabinet liner or Sealed Refrigeration System (compressor, condenser, evaporator, drier and tubing) which prove to be defective in materials or workmanship. Check with the manufacturer for any further details. Hope this is helpful. -Best Regards- WP
5/30/2014 3:13:31 PM • Frigidaire... • Answered on May 30, 2014
What is error code 1 on a Frigidaire FFHS 2622 MBE?
Good Afternoon Laura, I see that you are inquiring as to what an error code 1 is on your Frigidaire refrigerator, model# FFHS2622MBE. Error code 1 could possibly have something to do with the software that controls your refrigerator. I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Restore power to your refrigerator, and if you are still receiving an error code 1, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is going on with your refrigerator. Hope this helps. -Best Regards- WP
5/2/2014 7:39:22 PM • Frigidaire... • Answered on May 02, 2014
0answers
0answers
0answers
Refrigerator water dispenser has water to bottom of door but will not dispense
water is frozen up in door. try turning temp to freezer up a little.ive been able to thaw line by using hair dryer on inside of freezer door
3/14/2013 2:26:28 AM • Frigidaire... • Answered on Mar 14, 2013
Freezer temp is flashing 3
11/7/2012 4:24:06 PM • Frigidaire... • Answered on Nov 07, 2012
Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator Logo
59 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidaire frig code h 1 flashing model
  • Refrigerators
