20 Most Recent Frigidaire PLEB30T8A Electric Double Oven Questions & Answers
F43 error on Frigidaire Wall Ovn?
The code F43 means - The cooling fan speed, as read by the tachometer input of the EOC-display board, is abnormally too slow. when the cooker is on can you feel the fan is on through the upper vent? If not then the fan is the problem if you can then the fan sensor is the problem!
10/21/2014 4:45:28 PM • Frigidaire... • Answered on Oct 21, 2014
Lower element of upper oven
Hello & Welcome to FixYa
It indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
9/23/2011 5:07:46 PM • Frigidaire... • Answered on Sep 23, 2011
My top oven shows F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
8/18/2011 2:17:06 PM • Frigidaire... • Answered on Aug 18, 2011
Describe your Frigidaire model PLEB30T8CCA
Correct the problem is with thermostat, however your ovens thermsostats are electronic and are included in the board relays at diagram F80 partimage.aspx?imgid=z3bqljbfahrfmtawmjiwodezl0ldvy9zb3rvahb0cmfwlw%3d%3d
Enlarge Photo
Board - relay
Part Number: AP2127301 made by FRIGIDAIRE and the thermostat is complete with temperature sensor.
F37 partimage.aspx?imgid=z3bqljbfahrfmtawmdk0njezl0ldvy9zb3rvahb0cmfwlw%3d%3d
Enlarge Photo
PROBE
Part Number: AP3969435 made by FRIGIDAIRE
as you can see at the diagram
so the first thing is to replace the sensor which is the main suspect and if the problem insist then the relay.
7/28/2011 9:01:02 PM • Frigidaire... • Answered on Jul 28, 2011
Frigidaire double ovens F8 error and beeping
good day,
hope this link below will solve your problem.
ovens
8/2/2010 4:59:38 AM • Frigidaire... • Answered on Aug 02, 2010
Oven not heating KitchenAid KERC506HWH3
Built-in ovens have a thermal fuse mounted in the back of the oven preventing the bake and broil from operating. In some cases this fuse will open after a self clean operation. In some models, the cooling fan turns off too soon, causing an overtemperature condition that may also cause the fuse to open. You will have to remove the oven and take off the back panel to gain access to this device.
2/24/2009 2:36:09 AM • Frigidaire... • Answered on Feb 24, 2009
Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
4/18/2008 1:46:11 PM • Frigidaire... • Answered on Apr 18, 2008
How do I replace the probe
Yes and no the reason they ask you to cut them is the lenght of the wire does affect some of the probes (thermistor) it reads resistence and the longer the wire the more it will read if you want it to be for sure your model is this type do it the right way and pull the oven if you want to cut it in place then try the oven like that if you are happy with the temps then leave it the reason the wire wont pull out the is a zip strap holding it in the wire bundle behind the back wall.Hope this helps
1/21/2008 9:31:48 PM • Frigidaire... • Answered on Jan 21, 2008
2answers
Frigidaire Gallery Convection Oven CFEB786JGB3
Parts Schematic and wiring diagram. https://www.partselect.ca/Models/CGEB30S9FB3/ Part F161 is the Convection Element. Check it for continuity with a multimeter and also check the connection tags to it as they can melt. https://www.partselect.ca/PS2361497-Frigidaire-318255504-ELEMENT.htm?SourceCode=20&SearchTerm=CGEB30S9FB3&ModelNum=CGEB30S9FB3&ModelID=899380 ..
8/31/2023 11:47:04 PM • Frigidaire Ovens • Answered on Aug 31, 2023
Frigidaire Mdl: CFES387CFS6 oven controls do not work
If the display is blank then I would assume that the power board is dead and will need to be replaced
8/26/2023 6:41:46 PM • Frigidaire Ovens • Answered on Aug 26, 2023
Frigidaire Pro oven has error code F 14 and the temp probe has 1095 ohms. How do I troubleshoot the control panel?
F14 Misconnected keyboard cable Verify connection between display board and touch panel (2 ribbon cables). Make sure the cables are well connected at both ends. If the cables are good, replace the touch panel. If the problem persists, replace the display board.
8/1/2023 5:50:15 PM • Frigidaire Ovens • Answered on Aug 01, 2023
My frigidaire ovens broiler came on, on high, when i was baking at a very low temp (170).
If your Frigidaire oven's broiler unexpectedly turned on while you were baking at a low temperature, it could indicate an issue with the oven's temperature control system. Here are a few possible explanations and troubleshooting steps:
  1. Incorrect oven setting: Double-check that you have selected the correct oven function and temperature settings. Ensure that you have chosen the "bake" function rather than the "broil" function. Also, verify that the temperature setting is appropriate for baking.
  2. Malfunctioning temperature sensor: The oven's temperature sensor, also known as the oven thermostat, could be faulty. A malfunctioning sensor may send incorrect temperature readings to the oven control board, causing it to activate the broiler unexpectedly. Consider contacting a professional technician to inspect and potentially replace the temperature sensor if necessary.
  3. Control board issue: The oven control board, which regulates various oven functions, could be experiencing a malfunction. If the control board is sending incorrect signals to the broiler, it may activate when it shouldn't. Consult a professional technician to assess and repair the control board if needed.
  4. Wiring or electrical problem: Inspect the oven's wiring and electrical connections for any signs of damage or loose connections. Faulty wiring or poor electrical connections can cause erratic oven behavior. It's advisable to have a qualified technician examine the electrical components to ensure they are functioning correctly.
6/28/2023 4:10:16 AM • Frigidaire Ovens • Answered on Jun 28, 2023
Frigidaire Range FES367DBA
6/19/2023 4:24:18 PM • Frigidaire Ovens • Answered on Jun 19, 2023
Model #FEFL79DSA Frigidaire electric range. 2004 vintage. Last night wife was cooking supper at 350F. After half hour she noticed sizzling sound which was not normal.
Based on the information provided, it seems like there may have been a problem with the oven's thermostat or temperature sensor. It's possible that these components malfunctioned, causing the oven to continue heating beyond the set temperature. Since the issue seems to have resolved itself and the oven is currently functioning properly, it's difficult to determine the exact cause of the problem. However, if the issue occurs again, it's important to have a professional technician inspect and repair the oven to ensure that it operates safely and efficiently. Intermittent issues can be difficult to diagnose and can potentially be dangerous, so it's important to take any signs of malfunction seriously and address them promptly.
4/10/2023 7:42:43 PM • Frigidaire Ovens • Answered on Apr 10, 2023
2answers
How to remove a 1960s frigidaire compact 30 drop in oven?
unknown since fixya didnt install and dont know what installer did
4/2/2023 3:47:15 PM • Frigidaire Ovens • Answered on Apr 02, 2023
I have a Frigidaire oven that is giving a F3 code
Error Code: F3 Solution: The oven temperature sensor may be failing or defective. First, check sensor harness and harness connection between oven sensor and oven control to see if there is an issue with loose wires or visible damage to the wiring, such as a burnt wire.Sep 1, 2018
Frigidaire Error Codes Explained - D&T Appliance Service
3/8/2023 6:00:24 AM • Frigidaire Ovens • Answered on Mar 08, 2023
How do I jump test the limit switch on Frigidaire oven - FFEH3054USE?
Replace the switch...be sure to turn the Breaker to the unit off before servicing. https://www.repairclinic.com/ProductDetail/2453504?c=35 Their 800# people can assits you too, and videos on how it's done on the part discription.
2/23/2023 5:43:11 PM • Frigidaire Ovens • Answered on Feb 23, 2023
How do I take the door off the double oven Frigidaire professional series
Hello again :>D Videos
2/19/2023 12:15:59 AM • Frigidaire Ovens • Answered on Feb 19, 2023
Frigidaire PLEB30T8A Electric Double Oven Logo
Popular Tags
15 questions posted
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
f43 error frigidaire wall ovn
  • Ovens
