Hi
F8 error is door lock error, which states that the issue is with the door lock switch/latch and to resolve this problem you can change the part that has gone bad. Hope this helps...please post back for further questions.
Daniel
If one of the heating elements is not heating at all, then replace the heating element. You can test the heating element reading Ohms with a multimeter. You disconnect element and read impedance with multimeter set at Rx1. If the element has no continuity, and the circuit is open , then the element has blown. In that case you get no heating at all. Check if either broiling or baking element is not working.
F14 Misconnected keyboard cable Verify connection between display board and touch panel (2 ribbon cables). Make sure the cables are well connected at both ends. If the cables are good, replace the touch panel. If the problem persists, replace the display board.
If your Frigidaire oven's broiler unexpectedly turned on while you were baking at a low temperature, it could indicate an issue with the oven's temperature control system. Here are a few possible explanations and troubleshooting steps:
Incorrect oven setting: Double-check that you have selected the correct oven function and temperature settings. Ensure that you have chosen the "bake" function rather than the "broil" function. Also, verify that the temperature setting is appropriate for baking.
Malfunctioning temperature sensor: The oven's temperature sensor, also known as the oven thermostat, could be faulty. A malfunctioning sensor may send incorrect temperature readings to the oven control board, causing it to activate the broiler unexpectedly. Consider contacting a professional technician to inspect and potentially replace the temperature sensor if necessary.
Control board issue: The oven control board, which regulates various oven functions, could be experiencing a malfunction. If the control board is sending incorrect signals to the broiler, it may activate when it shouldn't. Consult a professional technician to assess and repair the control board if needed.
Wiring or electrical problem: Inspect the oven's wiring and electrical connections for any signs of damage or loose connections. Faulty wiring or poor electrical connections can cause erratic oven behavior. It's advisable to have a qualified technician examine the electrical components to ensure they are functioning correctly.
Based on the information provided, it seems like there may have been a problem with the oven's thermostat or temperature sensor. It's possible that these components malfunctioned, causing the oven to continue heating beyond the set temperature.
Since the issue seems to have resolved itself and the oven is currently functioning properly, it's difficult to determine the exact cause of the problem. However, if the issue occurs again, it's important to have a professional technician inspect and repair the oven to ensure that it operates safely and efficiently.
Intermittent issues can be difficult to diagnose and can potentially be dangerous, so it's important to take any signs of malfunction seriously and address them promptly.
Error Code: F3
Solution: The oven temperature sensor may be failing or defective. First, check sensor harness and harness connection between oven sensor and oven control to see if there is an issue with loose wires or visible damage to the wiring, such as a burnt wire.Sep 1, 2018
Replace the switch...be sure to turn the Breaker to the unit off before servicing.
https://www.repairclinic.com/ProductDetail/2453504?c=35
Their 800# people can assits you too, and videos on how it's done on the part discription.
If your Frigidaire oven is not heating up to the high temperature, there could be a few possible causes:
The thermostat may be malfunctioning: The thermostat controls the temperature of the oven and if it's not working correctly, it could prevent the oven from reaching the high temperature.
The heating element may be malfunctioning: If the heating element is not working properly, the oven may not be able to reach the high temperature.
The control board may be malfunctioning: If the control board is not functioning properly, it may not be sending the correct signals to the heating element or thermostat, preventing the oven from reaching the high temperature.
The oven may be in a cleaning or self-cleaning cycle: when the oven is in a cleaning cycle, the temperature is raised to a high level to clean the interior of the oven.
The oven may be in a energy saver mode: some ovens have a energy saver mode that decrease the temperature by a certain degree to save energy.
my best guess its A Frigidaire wall oven, circa 1966-1970,unsafe to use at any time if the temp controller trips the circuit breaker could be the oven thermostat causing the trip as well if Frigidaire are still in businessYou will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
My advice is never to use the self cleaning feature. Each time you use it you are a little closer to breaking something, elements, fans, door latches and one poor man who had a burned / melted control board which was obsolete so he had to purchase a new range. We see it here all the time. It is a great way to sell spare parts. 800 to 1000'F is just too severe for the parts.
