20 Most Recent Frigidaire FGB24L2A Gas Single Oven Questions & Answers
sounds like the clock assy. is bad part 316557206 heat usually is the cause of this part to fail,people use the self clean the oven gets up to 1000 degrees and damages the clock assy. or a large pot was on top of the stove and the heat damaged it but whatever the cause was you need to change out the clock assy. if the touch pad is black you can reuse it if it's white for some reason it doesn't peel off without damaging the overlay get a putty knife and a hair dryer,heat up the overlay and peel it off with the putty knife,go here to see the parts
https://www.searspartsdirect.com/model-number/FGFLMC55ECA/1428/0124002.html
it looks like this only comes with the black overlay because it doesn't show any other colors so you can order the overlay or peel it off and save some bucks,go to the sight,put your model number in,go to backguard and look at parts 20 and 20a this is what you need,first i would check all the wires going to the clock assy. to make sure there isn't a broken wire.good luck
Frigidaire... | Answered on Dec 24, 2017
Good Morning Jim, I understand that your gas range is inoperable. Let's try reprogramming the unit by either flipping the household circuit breaker off or unplugging it. While the unit is turn OFF; confirm that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. Then you may turn the appliance on. If the steps do not correct the issue, your range could be experiencing a communication error with the EOC (electronic oven control), a potential wiring failure, faulty bake or broiler element or power supply. I would personally contact a professional to accurately diagnose the appliance to determine the root cause to reduce the risk of unnecessary parts. If you do not know a professional technician, manufacturer websites often have service provider locators' onsite to assist you in that regard. If you have any additional questions, please feel free to reconnect!
Frigidaire... | Answered on Aug 23, 2013
Hi ivylsaga - Please try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit may possibly have a faulty EOC (electronic oven control), or a potential wiring harness. I would suggest contacting a professional to move forward accurately.
Frigidaire... | Answered on Apr 12, 2013
This is from Frigidaire website
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press STOP/CLEAR to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes to turn it back on.
If the code is still displayed after you've followed these steps, contact your local authorized service provider.
That is the best answer I can give. I hope it helps. I don't know what the code is, but it only gives this answer.
Joe
Frigidaire... | Answered on Aug 30, 2011
Hello, Thank You for using FixYa. I will be helping you today.Both error codes are to do with a runaway temperature or not sensing temperature correct. Make sure the oven sensor is plugged into the board correct or one of the wires wasn't damaged.Since the control was replaced i would make sure it was wired correct.The oven sensor or rtd probe is the short rod coming through the back oven wall in the top section. If all the wiring is correct and plugged in correct the probe is shorted or the relay on the control.
Thank You and please rate my answer if it was helpful..
Frigidaire... | Answered on Jun 16, 2011
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Frigidaire... | Answered on Mar 11, 2011
First check the power to the oven if the power is good look at the bake igniter I have seen it cause this same issue, let me know,
http://www.appliancerepairlesson.com/
Frigidaire... | Answered on Mar 07, 2011
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Frigidaire... | Answered on Sep 14, 2010
remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle, so it is easier to remove the burner tube. Remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. There is also a video at www.appliancehelponline.com/servicemanual.html that walks you thru testing this part. You can also enter your model # for diagrams and illustrations.
Frigidaire... | Answered on Apr 09, 2010
The problem is with the ignitor. You need to change the ignitor and the broiler will work right again.
This is a tip for ovens, but the same principle applies for broilers...
Check it out here...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Frigidaire... | Answered on Mar 14, 2010
to use the self clean you will need to turn the oven up to maximum for 1 hour.
Frigidaire... | Answered on Sep 28, 2009
Electronic control has detected a fault condition. Turn the Temperature Control Knob to OFF,
and disconnect the power to the range. Wait 30 seconds and reconnect the power. If fault
recurs, disconnect the power and contact an authorized servicer.
Frigidaire... | Answered on Dec 17, 2008
your unit dioes not have a pillot that would need need relighting, it instead uses a glow bar ignitor. auto pilot.
Frigidaire... | Answered on Dec 15, 2008
Click on this link and then look on the rifgt and click on guides and manuals. that will take you where you want to be. I hope this helps. http://www.frigidaire.com/products/cooking/built-in_ovens/single_gas/prod_FGB24L2A.asp
Frigidaire... | Answered on Dec 07, 2008
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Frigidaire... | Answered on Sep 30, 2008
The F10 error can be caused by a faulty relay or electronic control board if the oven overheated while in use. If you unplug the range and the error occurs when the range is cool, then the over-temperature sensor has failed or the electronic control board is faulty. Even the wiring between parts could be faulty.
You need to check sensor and wiring. On some models, the oven temperature sensor probe can be accessed by opening the oven door. Look for two screws that are close together. Otherwise it's accessed from the back of the oven. It may be covered by an access panel. Unplug the wiring harness and check the resistance across the sensor with a multi-meter. It should give 1100 Ohms. Similarly check the wiring resistance from the probe to the control board. Also check the relay and that wiring. Replace the wiring, sensor or relay if those are faulty. Otherwise you need to replace the control board. The control board will be behind the console access panel. Somewhere on the back of the range, there will be a trouble-shooting sheet giving the wiring diagram and the expected resistance or voltage across the parts of the range.
I may be able be able to provide a parts diagram and price list for parts on your range. Please add a comment with the model number of the range for this information.
I hope this helps.
Frigidaire Ovens | Answered on Jan 04, 2020
Frigidaire FGB24L2A Gas Single Oven Logo
25 questions posted
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
frigidaire gas oven
  • Ovens
