20 Most Recent
Frigidaire FMT118E1B Microwave Oven Questions & Answers
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Went to turn on the mic and heard a pop and now no
I had the same thing to happen to our microwave oven. I went and replaced the fuse in it. Power came back on. Then I tried to pop some popcorn in it. 30 seconds after it started, it made a vibrating noise and shut off. It took the fuse but not the curcuit breaker. The microwave is 14 years old. I have just come to the conclusion that there is buildup all inside the motor parts and that it needs to be replaced. The instruction manuel mentions to replace the monitor switch when replacing the fuse. Since I lost the manuel a long time ago, I asked at Lowes and noone knew what that was....I since found out that it was a safety device installed on the microwave oven so that if the door was not shut completely or was out of alignment, it would throw the fuse. Anyway, I am happy with the service we got with this microwave. It has been through several slammed doors and lots of use. We have been very satisfied with our Frigidare Microwave. It has held up well.
My Frigidaire gallery convection microwave keeps blowing its fuses
fuses inside oven, sure. (i had to guess)
all UWAVE do that when the 3 or 4 door switches CONTRADICT.
this is so it does no cook a persons eyeballs.(no really )
what we do is replace them all as a set,
4x5=$20 set.
I am on my 3rd set here, ( 18 year span)
so i even bought a new whole spare fuse panel (behind the controller) with new switch set pre loaded.all -in- one fix.
then when it fails i can replace it all in 30min flat.
mine is built in fancy uwave and do not want top put in any alien Uwave here and now wood cabinets must be modified.
see?
good luck,
Frigidaire pleb27m9ecd built in oven/microwave. The oven works fine. The plug on the oven that microwave plugs into is not working.
It sounds like you may have an issue with the plug that connects the microwave portion of your Frigidaire PLEB27M9ECD built-in oven/microwave to the electrical supply.
Here are a few things you can try:
- Check the power supply: Make sure that the oven/microwave is properly plugged into a working outlet and that the circuit breaker is not tripped.
- Inspect the plug: Look for any visible damage on the plug and make sure that the connections are secure.
- Check the wiring: Make sure that the wiring inside the oven/microwave is not damaged or loose.
- Test the outlet: Using a multimeter, test the outlet to see if it's providing power.
- Test the microwave: If you have access to a known good microwave, you can test the plug by plugging it into the known good microwave and see if it works.
If none of these solutions work, it's likely that there is an issue with the electronic control board or the plug itself, which will require professional repair.
It's best to contact the manufacturer or a professional technician for repair. They will be able to diagnose the issue more accurately and repair it.
My Frigidaire over the range microwave keeps blowing the fuse when I try to start it?
I had the same problem with this POS microwave. Bought it September 2019 and the plastic at top is brittle and breaking plus the door latch springs are WAY too stiff for this application. I'm 6'4" and it is hard for me to open and close. The spring tension causes the latches to slam down on the thin edge of the plastic catch causing divot wear. The INCESSANT beeping when food is done is worse than nails on a chalkboard plus there are Way too many levels and button presses to simply soften butter or cream cheese! What a TOTAL mess that I Absolutely regret buying! As for this issue with the blown fuses (on a 20 AMP circuit with nothing else on it); I read about replacing the switches so that is where I started but it didn't work. I noticed the wear in the latch catch so I ordered a replacement and that fixed the problem. I also found a video showing how to remove the door and change the latch. I did not need a new latch, but I did want to replace the spring. I have a box of springs at home and found one that was slightly shorter but the same diameter. It had about half the pull strength and now the door opens and closes reasonably! I hope this helps
Frigidaire Microwave Internal Light Bulb - HELP NEEDED PLEASE!
You are lucky!
MICROWAVE OVEN LIGHT Remove the louver per instructions 1-3 above and charcoal filter, if used.
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Open light cover located behind filter mounting by carefully pulling up on the front edge.
3. Remove old light bulb and replace only with equivalent watt bulb available from parts distributor. Bulbs are also available at most hardware stores or lighting centers. DO NOT USE BULB LARGER THAN 20 WATTS.
4. Replace the microwave oven light cover by carefully pushing into place. Replace the charcoal filter, if used. Push the louver back into place (engaging both the bottom and top tabs) and replace the louver mounting screw.
When in doubt, refer to the manual :>D
https://d1vofmza27mmhi.cloudfront.net/product-pdf/frigidaire-fgmv174kf-use-and-care-manual.pdf
