20 Most Recent Radio Shack 15-2142 Remote Control Questions & Answers
4answers
Need code for a legend tv
Hey there,
This brand uses the same code as sylvania/emerson. Try using the emerson codes, and that should give you the basic functions with remote. Here are some of the emerson codes. Just drop first 0 if your remote only takes three #s. Try each until one works. Good Luck!
0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
12/29/2015 9:05:26 PM • Radio Shack... • Answered on Dec 29, 2015
0answers
Need code list for starlite consumer electronics model:NP70PDKB
Set-up codes to check with NP70 are, 003,001,028,026. for more information go to http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
11/12/2013 3:10:15 PM • Radio Shack... • Answered on Nov 12, 2013
Radioshack 15-1993 4 in 1 apex dt250 codes
0938,0917,0992,0954. Check these codes. If you wish to get more, check these sites. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
10/2/2013 10:36:23 AM • Radio Shack... • Answered on Oct 02, 2013
Codes for my remote for my rca tv
Check this site for more details. It has more than 1450 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.Check this one too.
12/17/2012 11:30:56 AM • Radio Shack... • Answered on Dec 17, 2012
3answers
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too. Mcneileric is right! Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up. NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!Again...TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.Mcneileric, THANK YOU!!!!
6/23/2012 8:28:52 AM • Radio Shack... • Answered on Jun 23, 2012
Need codes for mitsubishi tv guide plus+
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
Check the code by Brand. Setup proceedings also given in detail. Refer more posts out of 225.
6/1/2012 10:10:07 AM • Radio Shack... • Answered on Jun 01, 2012
I CAN'T GET MY REMOTE TO WORK ON MY PEGASUS TV.
Just do a code search mehod, if you do not have its codes for direct entry.Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help. Pull up older posts there.
5/22/2012 5:07:57 PM • Radio Shack... • Answered on May 22, 2012
Need code for legeand tv dish remote
6744,9807,5543,9876,1097
3/26/2012 2:39:02 PM • Radio Shack... • Answered on Mar 26, 2012
I need a tv remote code for westinghouse ltv32w-1 hdtv
Try these setup codes.097/ 100 0143 0114 0100 0130 0138 0136 0227 0279 0080
3/12/2012 3:56:00 PM • Radio Shack... • Answered on Mar 12, 2012
Need codes for toshiba tv
Here are the codes for a Toshiba TV and DISH remote: 617,631, or 744AddressRemote to TV
  1. While at the device location (TV, etc), point the remote at the device. Press and hold the device button on the remote (TV, Aux, etc). - All four mode buttons should light up
  2. Enter the three-digit remote control code - The mode button (TV, Aux, etc.)you selected should light up
  3. Press the Pound (#) button - The mode button you are programming should flash three times
  4. Press the large, red POWER button - The device should turn off
1/7/2012 3:26:39 PM • Radio Shack... • Answered on Jan 07, 2012
Radio Shack 15-2142 Remote Control Logo
121 questions posted
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Radio Shack Televison & Video
Most Popular Question
need code legend tv
  • Televison & Video
