20 Most Recent ASUS Google Nexus 7 Tablet Questions & Answers
Nexus 7 16gb tablet won't power on
I would do a hard reboot. To do this you should hold down the vol up, vol down, and power buttons. This should bring you into recovery mode. Others seem to be having similar issues. Warranty?
3/11/2018 11:00:28 PM • ASUS Google... • Answered on Mar 11, 2018
My google nexus 7 wont turn on
Sorry to hear/read this. First, try get a new charger and plug your Google nexus 7. Suspect a dead battery with no charge left on it. Otherwise, confirm your charger isn't just lighting up whereas it isn't delivering any charge current to your device. Next to try if your ac charger is confirmed good is to attempt replacing the battery; at the store, have them insert a compatible/similar battery and then try power on your device. NOTE: New batteries at the point of purchase have some charge on them; sufficient to power on your device. Device not power on, DON'T PURCHASE NEW BATTERY. Obviously, you don't have a power/battery problem. Device power on, then you either have a battery that has failed or that your device's charging port needs to be serviced or repaired. Please post update/feedback asap. Thanks
10/11/2017 8:12:39 AM • ASUS Google... • Answered on Oct 11, 2017
0answers
How to reinstate Kindle app on my Google Nexus Tablet
That means the signal was lost not the app.
8/12/2016 7:12:09 PM • ASUS Google... • Answered on Aug 12, 2016
I fussed with the setup assesibility section of my trusty old nexus when a malware app suggested it. Oops.Help please?
Hi Harold, The link below is a YouTube video showing how to fix your phone/tablet, Also there's video's down the right side of the link that may help as well....CHEERS.. https://www.youtube.com/watch?v=0PAB6khykWE How To fix any Android Phone Tablet that won turn on
5/1/2016 10:40:48 AM • ASUS Google... • Answered on May 01, 2016
tip
Waking up nexus 7
Hi If you're Nexus 7 is a bit sluggish on first start up::: hold down the power button for 6 to 7 seconds it should reboot :: I have tried this with 2 they did operate normal after reboot....Cheers
Nexus 7, Android ver 6.0.1; can't authenticate my wifi; can see the ssid; tries to authenticate & shows "authentication prob." Also the wifi strength symbol shows blank.
Reads like you've got a faulty wifi module on the Nexus. Have you got warranty?
3/6/2016 10:56:07 PM • ASUS Google... • Answered on Mar 06, 2016
Why doesn't it turn off using switch?
Hold button down for a couple seconds. A screen should pop up asking to turn off device. Say yes. Hope this helps!
1/31/2016 8:20:33 AM • ASUS Google... • Answered on Jan 31, 2016
tip
Replace LCD and Touch Screen Assembly
Made a video on how I changed the LCD and Touch Screen Assembly on a 1st Generation 2012 ASUS Nexus 7. I also show why it's almost impossible to replace only the Touch Screen and had to replace the LCD and Touch Screen Assembly.
2answers
NO DISPALY AFTER FALL FRON 3FT. HEIGHT
go to service centre hardware is misplace if you are good in hardware open the back panel and you;ll see set of parallel wire stuck in jack remove it and put it back on same slot be sure your tab is switched off
12/15/2015 5:42:07 PM • ASUS Google... • Answered on Dec 15, 2015
2answers
It fell down from 3ft height since then no dispaly screen coming
You probably broke the screen or a cable popped out. I made a video on how I replaced the screen in one.
12/15/2015 5:32:04 PM • ASUS Google... • Answered on Dec 15, 2015
2answers
So I'm still confused. Does the Nexus 7 work with Microsoft programs?
Yes it does. You can get them from the Google Play store on your N7. MS Works though is not available.There are also several other apps which can handle MS Office files. .
12/6/2015 7:46:06 AM • ASUS Google... • Answered on Dec 06, 2015
2answers
My lad dropped his Google nexus 7 and it has stopped working , where can we send it to be repaired
Contact ASUS for a listing of authorised repairers for the Asus Nexus 7 or it may be listed in the user manual or in a separate document included in the original box. If you have one of the cheaper basic models it will most likely not be worth repairing as it will cost around the same to replace it and possibly less depending on which model you buy and the amount of damage. It is difficult for repairers of these items to quote on repair costs because they often don't know what the internal problems are until they run tests and dismantle it. Also if the damage is not repairable you will incur a service charge in any event. If it is one of the less expensive models I would not bother with a repair but buy a new one and wear the loss.
11/25/2015 10:25:09 AM • ASUS Google... • Answered on Nov 25, 2015
How switch off safe mode?
All you need to do is hold down the power button and tap on 'Restart'. Tap 'OK' if you're prompted.
9/7/2015 4:01:33 PM • ASUS Google... • Answered on Sep 07, 2015
2answers
How do I delete downloads from nexus 7
I assume you are in the downloads app if so just touch and hold for short while it should then select the file and the delete button should (trash can) appear at the top of the screen.
9/7/2015 3:55:47 PM • ASUS Google... • Answered on Sep 07, 2015
3answers
I can't unlock my Nexus 7
There is a good chance to do a hard reset but it wipes out all ur settings..for better info go to this linkhttp://youtu.be/Txn2v6xPcXwlet me know if it works for you.Chad man
9/7/2015 3:51:41 PM • ASUS Google... • Answered on Sep 07, 2015
3answers
Unlocking pin code
You can try to open it with your google account, but you must be near to the internet that you used before.
9/7/2015 3:50:03 PM • ASUS Google... • Answered on Sep 07, 2015
ASUS Google Nexus 7 Tablet Logo
161 questions posted
Top ASUS Tablets & eReaders Experts
k24674
john h
Ngoro
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Tablets & eReaders
Most Popular Question
fussed setup assesibility section trusty
  • Tablets & eReaders
