20 Most Recent
Fetco International CBS-2032 Coffee Maker Questions & Answers
How do I stop the water in my 2032
The only thing that comes to mind is the brew solenoid on the top of the machine. The gasket might be damaged or something is keeping it open.
2/12/2015 1:46:34 PM •
Fetco...
Answered
on Feb 12, 2015
Fetco cbs 51h drips water
Replace the brew solenoid on top of the sprayhead. Either something is keeping the spring and gasket open or the gasket is damaged. Get a rebuild kit from fetco or a new brew solenoid.
11/26/2014 1:34:22 PM •
Fetco...
Answered
on Nov 26, 2014
My fetco coffee brewing machine will not stop
This would be the bypass valve that is letting by. Depending upon which model you have taking off the top of the machine is straight forward and you will see the valve located near the outlet. You should be able to purchase a valve from the manufacturers agents in your area. It is a fairly simple swap out requiring basic hand tools and a little PTFE tape.
11/2/2013 1:16:57 AM •
Fetco...
Answered
on Nov 02, 2013
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
