20 Most Recent Jenn-Air 35 in. JEC9536 Electric Cooktop Questions & Answers
Jenn-Air JED8430BDB blowing fuse following ceiling fan work ...OUTside!
electricians do a couple of years learning the trade DIY people seldom get it right and generally hurt themselves or others by not getting it right you say you installed the fans and all worked well but the cook top is now blowing the circuit breaker What caused the light switch to short it is logical to say that somewhere in your wiring you have used a power or ground circuit that should not be used and that is causing overload or ground leakage problems before you try fixing the problem , you have to know exactly what happened and to get that information you will have to get in an accredited electrician to explain what was done wrong sorry that you will not appreciate the answer but there are too many people below ground because they did not recognize the simple fact that electricity and gas is not a diy domain
2/27/2017 10:56:06 PM • Jenn-Air 35 in.... • Answered on Feb 27, 2017
JEC9536bdb12 knob & gromet
call the company or e-mail the manufactor and see what they have in the store.
1/5/2013 9:03:05 PM • Jenn-Air 35 in.... • Answered on Jan 05, 2013
0answers
2answers
Hi, I have a Jenn Air
The noise stops because the fans bearings heat up and what is left of the grease starts acting as it should. The fans needs to be cleaned and oiled - an easy job that you should be able to do it yourself. Just be careful when dismantling the oven to access them.
10/8/2010 10:35:01 PM • Jenn-Air 35 in.... • Answered on Oct 08, 2010
How do I get the 'ALL-OFF/LOCK' light off? Also,
May I get the make and model # so I may help you more.
8/2/2010 12:54:18 AM • Jenn-Air 35 in.... • Answered on Aug 02, 2010
2answers
2 right burners on my Jenn-Air JEC9536 cooktop
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
7/2/2010 11:56:26 AM • Jenn-Air 35 in.... • Answered on Jul 02, 2010
Bought a Jenn-Air induction cooktop
Thanks for writing to Fixya.com.
Check the Supply feeding both burners switches if supply is there make sure the switches are good, if so the burners are at fault. You can find the complete instructions in the Service manual. Here are the breakdown diagrams and Replacement parts for JENN-AIR JED8430ADB | AppliancePartsPros.com
Thanks for contacting Fixya and please accept the solution if it has helped you.
4/6/2010 11:02:27 AM • Jenn-Air 35 in.... • Answered on Apr 06, 2010
Custom Control burner cuts off at highest setting
Hi, this is a fairly simple fix here. the custom burner control is malfunctioning. the chip set is bad. all you need to do here is to replace the burner control board. this will restore proper burner regulation.
Custom Control will run about $179.10
Click here to order
7/26/2009 7:50:16 PM • Jenn-Air 35 in.... • Answered on Jul 26, 2009
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
2/17/2009 4:06:11 PM • Jenn-Air 35 in.... • Answered on Feb 17, 2009
4answers
On light flashes
yes this is an indication that the element is burned out, replace it.
2/16/2009 8:40:13 PM • Jenn-Air 35 in.... • Answered on Feb 16, 2009
Wiring diagram
Hello
The wiring diagram is usually inside of the stove folded in a corner, or get the manual at the link I have provided and call them and they will email you one.
Check here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JEC9536&siteCd=JA_EN_US
Eddie Rentas
Tupper Lake NY
8/20/2008 3:23:45 AM • Jenn-Air 35 in.... • Answered on Aug 20, 2008
I need a manual for a Jenn-air cooktop PN 201595D
Jenn Air are high end and are Secretive with Service Manuals. You need a Service call and a whole load of money. It will be the controller or the board, or crack in the burner element. Even the controller switch is 150 bucks! https://www.google.com/search?q=Jenn-air+PN+201595D+manual https://www.appliancepartspros.com/search.aspx?model=c221%20pn%20201595e ..
12/23/2023 3:49:00 AM • Jenn-Air... • Answered on Dec 23, 2023
Jenn-Air C301 Cooktop. Wiring instructions for electric burner switch on a Jenn-Air model C301
Question edited for clarity, name of maker. Question moved to sub category. The service manual is here. You have to register. https://appliantology.org/files/file/4442-jenn-air-c301-cooktop-service-manual/ Other diagrams and text articles https://www.google.com/search?q=jenn-air+c301+wiring+diagram ..
9/27/2023 5:55:12 PM • Jenn-Air... • Answered on Sep 27, 2023
2answers
I have a Jenn-air electric ceramic cooktop. There's an issue with one of the surface control knobs. It now turns off in the "high" position instead of the "off" position. How do I fix this?
limited info generic answer check that control is mounted correctly test selector with a meter most likely its failing
7/24/2023 5:57:04 PM • Jenn-Air... • Answered on Jul 24, 2023
Jenn-Air Expressions Downdraft Gas Stovetop Model CVGX2423B - Unable to Get Nut Off Burner Base to Replace Igniters
It is possible to use WD-40 to help loosen the nuts, but it may not be enough on its own to remove them. Here are some steps you can try to remove the nuts:
  1. Turn off the gas supply to the stovetop and unplug the unit from the electrical outlet.
  2. Use a wrench that fits the nut snugly and try turning it counter-clockwise to loosen the nut.
  3. If the nut is stuck, try spraying a generous amount of WD-40 onto the threads of the nut and let it sit for a few minutes.
  4. After the WD-40 has had a chance to penetrate the threads, try turning the nut again with the wrench.
  5. If the nut still won't budge, try gently tapping the wrench handle with a hammer to help loosen the nut.
  6. If all else fails, you may need to call a professional technician to remove the nuts safely.
It's important to note that improper removal of the nuts could cause damage to the stovetop or cause a gas leak, which could be dangerous. If you are unsure about how to proceed, it's best to call a qualified technician to help you.
4/23/2023 7:31:56 AM • Jenn-Air... • Answered on Apr 23, 2023
Is there anyway to remove the Downdraft Filter Tray for a Jenn-Air Gas Cooktop
where there is a will there is a way --correct you will break it - it is tacked to frame ---to remove it you need to tear apart the unit ---purchase a claw style part retrieval tool $4 at harbor freight -$11 home depot---lowes etc
4/25/2022 3:06:28 PM • Jenn-Air... • Answered on Apr 25, 2022
The burner-on indicator light is flashing for the right front burner on my Jenn-Air 9530ADW electric cooktop and the burner won't come on.
The flashing pilot light probably means the element has failed and it is in need of a repair.
7/11/2021 7:37:00 PM • Jenn-Air... • Answered on Jul 11, 2021
3answers
I need Part No. PHS120A-3377
Hello & Welcome to FixYa
Part PHS120A-3377 has been replaced by part# 74009254 which you can buy from either this link or from sears. Please get back to me if you have any other questions.
Kevin
4/28/2020 2:08:34 PM • Jenn-Air... • Answered on Apr 28, 2020
I have a electric cooktop,when I turn on a burner the one next to it turns on as well .If I take the other cartridge and swap it out, it does the exact same thing.It is brand new unit right out of the
sounds like you may have a bad harness or bad infinite switch, you can test it with a multi meter. Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges,the oven temperature sensor is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
  1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
  1. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
  1. Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
  1. Repeat the step above for the terminals "L2" and "H2".
  1. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
  1. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
  1. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens usean electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter.If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve.This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced. http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/ https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on- element burner testing range element-short.2-undefined-undefined-0.gif infinite switchs stove-undefined-undefined-2.jpg infinte switch_noheat_03-undefined-undefined-5.jpg oven harness ge-switch-ignition-harness_l-undefined-undefined-9.jpg if the harness is damaged it may effect any of the others down the line as well causing the burners to act up as they are wired in series
3/17/2020 4:29:34 AM • Jenn-Air... • Answered on Mar 17, 2020
Jenn-Air 35 in. JEC9536 Electric Cooktop Logo
18 questions posted
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Cooktops
  • Jenn-Air Cooktops
Most Popular Question
jenn air
  • Cooktops
