20 Most Recent
Sigma 24mm F1.8 EX DG Aspherical RF Nikon - Black Questions & Answers
Nikon d7000 keeps flashing fEE
This is with the Sigma 24mm? If this is with the Nikon 24mm AF-D or another lens with an aperture ring then turn the aperture ring to its smallest setting (largest f/number) and control the aperture from the camera body the same way as with a lens without an aperture ring.If it really is with the Sigma lens, try cleaning the contacts on the back of the lens and in the lens mount on the camera body.
Where can I find out how to take apart a Sigma 150-600mm contemporary lens?
Taking it apart is not the problem - re-assembling it will be. Unless you have access to an optical laboratory, where laser instruments can measure the exact tolerances required, don't even think about it. You will be left with a pile of optical components, and a far higher repair bill than if you had just let the experts sort out the problem in the first place.
My sigma 50-500 lens is lock in 500mm position
I believe on some Sigma lenses there is a switch to lock it in a 'Macro' position, usually at the long end of the zoom range. If this applies to your lens, it may be worth checking that this has not been accidentally set. There may also be some information in the manual whichcame with the lens.
HOW TO TURN ON TV WITHOUT REMOTE CONTROL DEVICE?
Hello Dan, depending on the age of TV you should find an auxiliary power button to the rear of the telly usually on the left as you look at it.
They are often tiny and multi-function, especially if it's HD or 'smart'
