20 Most Recent CyberPower OfficePower 825AVR UPS System Questions & Answers
Looking for manual for Cyberpower 825avr
You can find the user manual for yoru Cyberpower CPS825AVR here: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
5/23/2011 6:50:06 PM • CyberPower... • Answered on May 23, 2011
5answers
My computer won't boot and the CyberPower 825 AVR makes a continuous sound.
It sounds as though the UPS is not receiving power. Check that it's cable is properly plugged into the wall. Also verify that it's internal ground fault interrupter has not tripped, it's usually a little red button on the back of the unit, it should be pressed in and should stay that way, if it pops out then there is a problem with the ground of your electrical outlet. Also check that the breaker for that electrical has not tripped at your fuse box.
Since the UPS is not receiving power the batteries have discharged and that is why your computer cannot start, there is not enough juice from the UPS to boot it. That is also why it is making a noise as most UPS's sound an alarm to indicate that they are not connected to power.
There is a chance that the batteries in your UPS have gone bad or that something has become faulty in your UPS. Try plugging your computer and monitor directly to the wall bypassing the UPS to see if they work fine.
12/17/2009 5:09:46 PM • CyberPower... • Answered on Dec 17, 2009
I need sound drivers
look for your computers home page and there you should find all the drivers for your specific make and model. make sure you know what kind of precessor and soundcard and video card you have though
12/6/2008 11:27:10 PM • CyberPower... • Answered on Dec 06, 2008
Cyber power 825Avr back-up
You may need to change you backup batteries.
11/29/2008 4:21:50 PM • CyberPower... • Answered on Nov 29, 2008
Lost software
Follow this link, to download PowePanel Plus for your UPS.
Click Here.
2/26/2008 12:13:10 AM • CyberPower... • Answered on Feb 26, 2008
Battery/Surge outlets not working...
Sounds like the UPS battery is bad, or the circuit break on it has gone. Is there a reset button on the UPS? Do you have the program that came with the UPS to check the battery status, those programs typically let you run a test on it also.
1/30/2008 3:00:06 AM • CyberPower... • Answered on Jan 30, 2008
CyberPower 825AVR backup
The cyberpower website hosts the software for free. Go here http://www.cyberpowersystems.com/support/product-support.html select your model and it will take you to the appropriate software suites.
12/19/2007 8:01:12 AM • CyberPower... • Answered on Dec 19, 2007
Why does my cyberpower ups 1350avr show constant overload with nothing plugged in.
Please discard. Probably a short circuit in the inverter!
1/3/2022 7:56:34 PM • CyberPower... • Answered on Jan 03, 2022
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
10/16/2017 2:29:54 PM • CyberPower... • Answered on Oct 16, 2017
0answers
When there is a power surge the (power quickly off then back on), the unit doesn't provide battery power (connected items turn off), and the unit starts to beep.
just unplug the UPS and check for how long it runs on batteries, if time is short just replace the batteries. if you are using a line interactive UPS you may have to replace it by an online UPS
6/18/2015 6:12:13 AM • CyberPower... • Answered on Jun 18, 2015
0answers
Constant buzz
Be the first to answer 5/28/2014 3:33:42 AM • CyberPower... • Posted on May 28, 2014Be the first to answer
300 watt manual
Your not asking the right question. The answer is dependent upon how long you want the backup to work. Does a battery fit in the unit or is it alone? If you were to connect a car battery to the unit it would run for many hours, say a motorcycle battery would run maybe an hour. It is all about the time you want for run time.
3/30/2014 10:34:59 AM • CyberPower... • Answered on Mar 30, 2014
CyberPower OfficePower 825AVR UPS System Logo
9 questions posted
Top CyberPower Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • CyberPower Computers & Internet
Most Popular Question
looking manual cyberpower 825avr
  • Computers & Internet
