20 Most Recent
CyberPower Office Power 585AVR (obcps585avr_1) UPS System Questions & Answers
The cyberpower 585 AVR suddenly isĀ“nt working...
the ups hardware of the relay and driver might be spoil..ask of the service? you can try this asia systems technologies look for our sale person william +65 65478990
[email protected] i suspected that now that u UPS is have hardware issue.. to determine if the unit is really the problem it hav to be do a further diagnos..
When power goes out, it turns off.
Yes, that could be the case. Eventually, a battery will be unable to recharge and would need to be replaced.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP7-12 battery).
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at [email protected].
585avr isn't working w/vista OS,
While the 585AVR is not designed for Vista, it should work. You will need to use the CyberPower serial to USB cable, and the most recent version of PowerPanel Personal Edition software. You can download the latest software @
http://www.cyberpowersystems.com/software/PPPE_V_1.2.2_Setup.exe
If you have any questions, or need the CyberPower serial to USB cable, please contact CyberPower Systems Technical Support at 877-297-6937, M-F, 8-5 Central.
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
300 watt manual
Your not asking the right question. The answer is dependent upon how long you want the backup to work. Does a battery fit in the unit or is it alone? If you were to connect a car battery to the unit it would run for many hours, say a motorcycle battery would run maybe an hour. It is all about the time you want for run time.
