20 Most Recent CyberPower 725SL UPS System Questions & Answers
0answers
I have a CyberPower 725SL UPS. Shortly after
Couple different items to check.
  • Try letting the unit set ideal for overnight charging the battery. Do not even turn the unit on.
  • Replace the battery.
If you turn the unit on when the battery is plugged in and does not keep a charge you can almost be sure it is the battery or the charging circuit not maintaining the battery.
11/11/2010 4:20:03 AM • CyberPower 725SL... • Answered on Nov 11, 2010
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
2/9/2010 6:03:32 AM • CyberPower 725SL... • Answered on Feb 09, 2010
UPS clicks off and when you hit reset button, it
ur UPS is not charging the battery....
try to change the battery inside...it may be dead...
12/21/2009 5:56:44 AM • CyberPower 725SL... • Answered on Dec 21, 2009
2answers
Cyberpower 725sl
Yes, it would appear that you need to replace the battery on this unit.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP9-12 battery).
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at [email protected].
10/23/2009 3:30:56 PM • CyberPower 725SL... • Answered on Oct 23, 2009
2answers
Cyberpower 725SL Intelligent Back Up Power
It would appear that you need to replace the battery on this unit.
10/22/2009 10:11:24 PM • CyberPower 725SL... • Answered on Oct 22, 2009
My UPS Cyberpower 725SL is blinking and clicking on and off
When the battery is low, or dead, on these it will act this way. You may want to try a new battery. Here's a supplier: http://www.batteryinternational.com/cyber-power-cps725sl-ups-battery-ups-batteries-f1.html
6/2/2009 10:47:00 PM • CyberPower 725SL... • Answered on Jun 02, 2009
2answers
Battery replacement
The batteries are very easy to replace on this model. You can simply remove 6 phillip head screws in the bottom and the unit will come apart to reveal the battery. Simple fast-on connectors. Here's a link to a new battery for that model: http://www.batteryinternational.com/cyber-power-cps725sl-ups-battery-ups-batteries-f1.html
6/2/2009 10:44:09 PM • CyberPower 725SL... • Answered on Jun 02, 2009
2answers
Power is out
Tom, usually those can be replaced by the End User. It's rare that they'd be sealed inside, but that does happen at times. The big issue is finding replacement batteries of same type/size fit, and you'd need to do that online.
2/6/2008 3:53:38 AM • CyberPower 725SL... • Answered on Feb 06, 2008
Why does my cyberpower ups 1350avr show constant overload with nothing plugged in.
Please discard. Probably a short circuit in the inverter!
1/3/2022 7:56:34 PM • CyberPower... • Answered on Jan 03, 2022
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
10/16/2017 2:29:54 PM • CyberPower... • Answered on Oct 16, 2017
0answers
When there is a power surge the (power quickly off then back on), the unit doesn't provide battery power (connected items turn off), and the unit starts to beep.
just unplug the UPS and check for how long it runs on batteries, if time is short just replace the batteries. if you are using a line interactive UPS you may have to replace it by an online UPS
6/18/2015 6:12:13 AM • CyberPower... • Answered on Jun 18, 2015
0answers
Constant buzz
Be the first to answer 5/28/2014 3:33:42 AM • CyberPower... • Posted on May 28, 2014Be the first to answer
CyberPower 725SL UPS System Logo
Popular Tags
13 questions posted
Top CyberPower Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • CyberPower Computers & Internet
Most Popular Question
cyberpower 725sl
  • Computers & Internet
