20 Most Recent
Breezaire WKE 6000 Wine Cooler Questions & Answers
Can you advise what type
TYPE OF THE REFRIGERANT IS LOCATED ON THE TAG ON THE BACK OF THE UNIT IT COULD BE AND R-22 OR AN R-134A
AND IT USES 22 oz OF REFRIGERANT WHAT EVER THE TYPE THE UNIT IS.
Front of unit freezing
IT COULD BE ABAD BLOWER CAPACITOR NOT STARTING THE BLOWER ON COLD SIDE CAUSING THE COIL TO FREEZE DUE TO LACK OF AIR FLOW OR A FREON LEAK
WCISERVICE.COM
The compressor will run at
IF UIT IS A YEAR OR LESS OLD YOU ARE BETTER OFF CONTACTING THE MANUFACTURER, SINCE THE UNIT HAS WARRANTY FOR PARTS AND LABOR DURING THE FIRST YEAR THEY WILL COVER ALLSO THE FREIGHT COST.
CALL THEM 858-566-7473
Fan runs, but no cooling
clean both coils(fins)and drain use non-detergent non additive oil(not motor car oil) for fan motor take cover off compressor relay and inspect wires(clean plugs and pins of oxide) you may need a hard start kit if it has a hard time starting
