20 Most Recent
HP P2360AA Keyboard/Mouse Questions & Answers
Wireless not working
I'd replace the batteries first, even if you've done so recently. If that doesn't fix the problem, try it on a different computer. My six year old HP computer came with a very similar setup. Look for a reset button on all three of the components and press them.
A red light came from
rule 1, never post email addresses, unless zillion spams in your email forever is fun?
what PC? the books are free at HP, but you never told me which PC you own so cant not answer 100% accurate.
what mouse. P2360AA ok, google shows...
ahh wireless, try a new battery (4xAA) in the wireless devices.
they use a battery so it can talk to the unstated PC to function.
your only risk is a dad mouse or dead keyboard,
it will never ever go to Phasor Overload. (Star Trek)
read the manual much.
hp has the manual, read it , to learn what those indicators mean?
there are 3 pieces, here, kbd, mouse and wireless panel box.
the USB receiver box, has lamps too.
you are saying the LED that glows is on top of the mouse.
?both the mouse and KBD both have batteries and a hatch to reach them.
read page 6 in your manual.
the kbd has many lamps tool call covered in the manaul
google finds the manual in 1 second, flat.
the mouse bottom does have and LED that makes it work.
these HP devices all warn you when the batteries get low.
so say HP.
or ask them your self.
https://h30434.www3.hp.com/
Mouse has a mind of it's own...often skipping
it might be due to scroll speed of mouse going bit high.
to adjust the same...click on start...control panel...mouse icon...mouse properties window would open... click on the pointers tab...adjust the pointer speed setting... this should help in fixing the issue.
regards
Hello;
It has to be a button you might have pressed near the mousepad on the notebook. Try clicking that button again, the red light will go off.
A red light comes on
It shows that you have accidentally shut off the touch pad. In the upper left corner of the touch pad is a dimple/circular depression. Tap it twice, the light will go out and normal touch pad function will return.
Shift fn keyboard issue
Its shifting to numeric for one key only.
Try changing the batteries, if that does not work, bin it.
Keyboard that skips letters while
Hello i have the same issue on my hp. however ihave been to apple store and used computers there and see this go on. someone on web sight mention mal ware. possible i also have a bar on my laptop i did not install that came off an attempt to down load acrobat flash player, its called v something. v grabber. and ihave gone into add ons etc remove programs and it wont go away.
