20 Most Recent Jenn-Air JJW7530DDS Electric Single Oven Questions & Answers
You have inadvertently entered the Sabbath Mode.
Try holding the clock button for 5 seconds to clear it out.
Jenn-Air... | Answered on Dec 31, 2014
Looks like it might be the high limit switch. This has instructions for changing it also. http://www.partselect.com/Models/JJW7530DDS/Instructions/
Jenn-Air... | Answered on Dec 07, 2013
Switch contacts fused together
In most external fittings there is a live coming from the switch a neutral going back to the lighting ring main and an earth wire for protection
You are not competant to be rewiring any house wiring , the statement about the earth wire proves that.
No earth is akin to jumping into a lake without a life preserver on
Get an electrician involved before you burn the house down
Jenn-Air... | Answered on Dec 31, 2009
I replaced the C3 capacitor on the circuit board as another person on FixYA had recommend and it works fine now. $4.00 versus $180.00 was worht the chance to try it.
Jenn-Air... | Answered on Mar 22, 2009
The door switch is probably bad and not actually opening when you shut the door. Replace it.
Jenn-Air... | Answered on Jan 05, 2009
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Jenn-Air... | Answered on Mar 19, 2008
Yes, this design catches all knids of things but it keeps those "crumbs" from getting inside the door facing. This also acts as an air relief for the oven.
Jenn-Air... | Answered on Jan 26, 2008
Hi
If you have connected correctly and the ribbon cable is also fine then it seems that the touch pad is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jenn-Air Ovens | Answered on Apr 15, 2019
CALL A REPAIR SERVICE LOCALLY WE COULD NEVER GUESS AT WHAT WENT WRONG WHEN NOT BEING USED FOR YEARS CORROSION HAPPENS
Jenn-Air Ovens | Answered on Apr 13, 2019
FR Second oven error sensed
The unit never detected a sufficient rise in temperature in the second oven.
Jenn-Air Ovens | Answered on Jan 24, 2019
wet shorted circuits
Jenn-Air Ovens | Answered on Dec 18, 2018
Request the manual directly from JennAir
Jenn-Air Ovens | Answered on Nov 13, 2018
Jenn-Air JJW7530DDS Electric Single Oven Logo
Popular Tags
9 questions posted
Top Jenn-Air Ovens Experts
Nathan Van Boven
Nathan Van Boven
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
View Most Popular
Jenn-Air Ovens
  • Jenn-Air Ovens
Most Popular Question
oven light will not turn off
  • Ovens
