20 Most Recent
Microsoft Standard Wireless Optical Mouse Questions & Answers
Can i download driver so i can use wireless mouse
Unless you have an old system, (win 98 ?) the mouse SW should load automatically. Just plug in the bluetooth dongle. Fresh battery in the mouse and turn it on. should detect and load. If not, it may be the really cheap mouse is garbage and not worth the 10 bucks you paid for it. If you REALLY need to download the latest driver, visit the mouse manufacturers web site and locate the driver there.
11/11/2013 7:14:00 PM •
Microsoft...
Answered
on Nov 11, 2013
I have microsoft standard wireless
Physically it is possible if you had a replacement switch and you/or a technician could install it.
Contact a computer store and ask them if they would repair it for you. Another option is to claim warranty support.
It is rather difficult to repair it ones self as the correct switch or PCBoard needs to be acquired and connected together.
You may need to purchase another mouse.
Take care!
damnor01
5/28/2011 8:37:31 PM •
Microsoft...
Answered
on May 28, 2011
My MS standard wireless optical
After you replace the batteries on a wireless mouse you must then sync it to its base. To do this, you must first push the button on the top of the base. The light will then start to blink. Then, you must push the button labeled "connect" on the bottom of the mouse.
5/7/2011 5:16:41 PM •
Microsoft...
Answered
on May 07, 2011
Mouse did not connect to receiver
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
The mouse uses two AA 1.5Volt batteries, ensure that they are installed in the correct orientation. Positive and negative polarity, on each. New strong batteries are required for this application.
A red light shoud elumanate from the bottom of the mouse when batteries are installed.
Now connect the USB cable from the receiver to the USB port on your computer, you may need to try different ones.
Once this stage has been completed you can install the drivers for your Microsoft mouse, they can be found on the CD disk that came with your Mouse.
The drivers may need to be installed using a wired mouse.
Beneath the mouse there is a button, press it.
On the receiver there is a button press it.
The receiver will now find the mouse and connect.
Thanking you kindly
damnor01
2/11/2011 7:18:02 AM •
Microsoft...
Answered
on Feb 11, 2011
I do not believe my
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
hope this helps
hope this helps
2/1/2011 6:29:58 AM •
Microsoft...
Answered
on Feb 01, 2011
When I turn on my desktop computer, the mouse and
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
make sure the leads are securely seated and are not bad/faulty
hope this helps
make sure you have the correct keyboard and mouse selected
you might have to uninstall your keyboard and mouse then restart your computer and reinstall them make sure that you have there drivers backed up on a disk before uninstalling them
click start control panel,keyboard select hardware you will see which keyboard it is this will also apply to your mouse
also select properties,general you will have options to troubleshoot,driver roll back uninstall ,update driver
or click start control panel administrive tools computer managent device manager scroll to keyboard you could see a yellow question mark? right click to install drivers
2/1/2011 6:06:48 AM •
Microsoft...
Answered
on Feb 01, 2011
How do i connect the mouse with my computer
Connect the USB to the port of your PC. Now the PC must detect the new device and install the device to your PC unless the OS is of older version. Now the mouse which has the battery inserted will be detected on the PC.
If this wont work you must download the drivers and install them from the microsoft website .. optical mouse drivers link for your OS.
1/21/2011 12:25:27 PM •
Microsoft...
Answered
on Jan 21, 2011
Mouse is frozen..keyboard is not
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
11/29/2010 8:55:37 PM •
Microsoft...
Answered
on Nov 29, 2010
