20 Most Recent
Philips DVDR3440H DVD Recorder/HDD Recorder Questions & Answers
Status on recorder says load and I cant move it off there
I would take the other route: The remote can be tested without the unit--all shops(ours does) have a tester--point the remote and press any or all buttons and the tester reacts if the remote is sending a signal.Some digital cameras will react in the same way on their display screens in a dark room with a flash.check the remote first.
6/17/2012 5:07:25 PM •
Philips...
Answered
on Jun 17, 2012
My draw will not open
If you hire sound of motor (when you push the switch) who open the door then is rubber band on wheel inside DVD, or cd is stuck inside. In that case you can hook door with something and pool up easy!
If no light on displey, or don`t hear motor (when you push the switch) then is electronic circuit in DVD, then you must go in service.
Good luck.
2/27/2011 1:33:07 PM •
Philips...
Answered
on Feb 27, 2011
I have a phillips DVD recorder DVDR3350
my dvd recorder has the same problem press the open/close button if this doesnt work when you press open again try hitting it very lightly on top as that is what i have to do to mine to get it to open sometimes
8/21/2009 6:04:01 PM •
Philips...
Answered
on Aug 21, 2009
Which blank dvds work best with phillips dvd
dvd-r are more universal if you plan on giving the copy to somebody. they are more lickley to play on older dvd players. they are not rewriable though one time record. also do not purchase spindles the bottom of the stack usually gives you problems when finalizing
6/3/2009 11:04:57 PM •
Philips...
Answered
on Jun 03, 2009
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless, I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
10/20/2008 10:05:17 AM •
Philips...
Answered
on Oct 20, 2008
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
8/30/2008 11:59:52 PM •
Philips...
Answered
on Aug 30, 2008
