20 Most Recent
LG DR198H DVD Recorder Questions & Answers
Philips Recorded DVD (Divx) won't play on computer
you can go to divx web page and download a convert tool this should allow you to watch your dvd's and burn them to a more compatable format
also try Realpay.com this also recon. divx & you can also burn new disc with this player in mp3, mp4,cd&dvd. modes.P
Recorded DVD won't play on computer or other players
Yes it might be the format of the recorded dvd, check in which format it is and you can then download the codecs for your PC movie player via google. If you can give me the format I can try and find you a link to the codecs you need if you like.
Goodluck^^
LG DR198H remote connection
your ir sensonr might be corrupted try to find a replacement and swich it /hope you didn't throw out your old RC it might still work
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
