20 Most Recent Lite On HD-A760GX DVD Recorder / HDD Recorder Questions & Answers
0answers
0answers
0answers
LITE ON HD-A740GX ONLY HAVE DIGITAL SIGNAL HOW DO I TUNE IN CAN I TUNE IN
You must connect a digital TV box between your arial and your Liteon, so the arial cable goes into the digital box, and use a SCART cable from the digital box to the Liteon. Then record using the SCART input on the Liteon. Another SCART cable can be connected from the Liteon to your TV, so you can view what you have recorded.
1/13/2014 5:08:49 PM • Lite On... • Answered on Jan 13, 2014
Will not load disc
Please have your lens cleaned by lens cleaner and retry. You will need to replace th lens if after several times cleaning but no results.
Regards
2/2/2011 3:20:55 PM • Lite On... • Answered on Feb 02, 2011
0answers
Hi, iv got a liteon
Be the first to answer 12/21/2010 1:38:44 PM • Lite On... • Posted on Dec 21, 2010Be the first to answer
I have a liteon A740/760 DVD recorder, and I have
are you running your tv through cable, satellite or antenna
9/2/2010 4:50:28 PM • Lite On... • Answered on Sep 02, 2010
Manuel for LVW 1107 dvd recorder lite on
Hi Tony- I found this link to download a copy of the manual. https://www.scoop.it/topic/jtzkncj/p/4100874528/2018/08/21/lite-on-lvw-1107hc1-manual Hope this helps.
12/3/2019 1:34:21 PM • Lite On... • Answered on Dec 03, 2019
Lg60pb6650 stand lite on -turn on with remote relay clinks -screen flashes gray - then repeats -found 2nf capacitor blown on upper buffer board-tried to replace the capacitor but hard to do. Reinstall
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
8/22/2017 6:12:57 PM • Lite On... • Answered on Aug 22, 2017
0answers
TLX-04243B Dead set Red blink lite on right front corner
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1/17/2017 7:18:32 AM • Lite On... • Answered on Jan 17, 2017
2answers
I am looking for parts for my liteon lvw-5055gdl
try nte.com semiconducter
1/2/2014 11:43:23 PM • Lite On... • Answered on Jan 02, 2014
-DVD Door will not open :(
FIrst switch Off the power supply.There is a hole just beneath the DVD tray. take a thin wire or unfold a office paper clip.Push the wire gently and the DVD will come out. There can be a mechanical failure, due to which it happened. switch On power supply, take our DVD try two -three times, if it works normally then i think ou problem is solved
12/25/2013 7:39:08 PM • Lite On... • Answered on Dec 25, 2013
Lite On HD-A760GX DVD Recorder / HDD Recorder Logo
15 questions posted
Top Lite On Televison & Video Experts
Ngoro
ADMIN Eric
ADMIN Eric
August Brown
August Brown
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Televison & Video
Most Popular Question
liteon a740 760 dvd recorder
  • Televison & Video
