20 Most Recent Nikon F60 35mm SLR Camera Questions & Answers
What does the error message F8 mean and how can I fix it? (Nikon F60)
Probably means the film has not been loaded correctly. Look in the manual for instructions on how to do this.
2/24/2022 7:27:56 PM • Nikon F60 35mm... • Answered on Feb 24, 2022
On/off on my nikon f60
7/18/2016 5:35:46 PM • Nikon F60 35mm... • Answered on Jul 18, 2016
Mirror has a crack
needs repairing at a qualified shop
2/13/2015 3:54:28 AM • Nikon F60 35mm... • Answered on Feb 13, 2015
Nikon f60 camera manual
The F60 was called the N60 in some parts of the world. You may download the N60 manual from http://butkus.org/chinon/nikon/nikon_n60/nikon_n60.htm
5/10/2014 4:50:25 AM • Nikon F60 35mm... • Answered on May 10, 2014
Shutter gear sound
The shutter in this camera does not have gears. Gears are used for film transport and cocking the shutter. Nikon stopped selling parts last year so unless you can find them on eBay you are pretty much out of luck. you can get to the gears by removing the bottom cover.
1/21/2014 7:28:11 AM • Nikon F60 35mm... • Answered on Jan 21, 2014
manual
Do you know what the
It's a near worthless model as are all of the similar Kodak designed and manufactured (for Nikon) consumer grade models, sorry. They're fine cameras, but they were not built to last and all are so far long past their 5 year design lifespan that they are a liability to a trader. They're not even attractive to most Nikon collectors and they're well aware that they can be picked up for nothing. Even if perfect it's true value to the trade is a maximum of £5, provided it has a working set of batteries which cost more than the camera is worth. No batteries and the camera is worthless even if perfect. You can definitely negotiate a bigger discount than than without a trade-in.
Lenses are a different matter; if they're the bundled kit lenses and in perfect condition then again they're only worth about £5 each at trade-in value, but if they are higher quality metal lens mount models then valuations are potentially much higher, but it 's all on a case by case basis.
You will get a far better price by selling your camera privately.
8/20/2011 11:42:03 AM • Nikon F60 35mm... • Answered on Aug 20, 2011
0answers
2answers
Nikon N60 SLR camera
It is more likely that the tab has separated from the plate it slides on. The spring is attached to the plate with the tab sticking out from it. I have repaired these in the past by boring a small hole in the backside of the tab and use a screw to re-attach it.
10/24/2010 1:20:59 AM • Nikon F60 35mm... • Answered on Oct 24, 2010
Broken shutter curtain
Fixing this requires a complete new shutter assembly and it's not a DIY job. Spares availability is also now very poor.
You can easily get a complete similar replacement SLR for a lot less than the cost of repair, so your best bet is to harvest every single removable accessory from the body and recycle it. A replacement camera should be dirt cheap or free as this and similar models are effectively worthless these days unless they're known to be collectable models (the F60 definitely isn't collectable). I get all of mine from my local FreeCycle and Freegle groups, some are boxed and virtually unused with all accessories, like the F75 kit and F-801 which I recently obtained.
Sorry that there's no realistic option to fix your camera, but I hope that my answer has given you a realistic alternative means to solve your problem. Please take a moment to rate my free answer.
10/7/2010 10:50:16 AM • Nikon F60 35mm... • Answered on Oct 07, 2010
Why does f33 keep coming up when i try to take
Having gone over a month without a response, I assume this is no longer an issue.
5/21/2010 5:30:42 PM • Nikon F60 35mm... • Answered on May 21, 2010
F EE
This means one of two things:-
1. You have not set the lens to it's smallest aperture before fitting it to the camera body; or...
2. The EE servo coupling post on the outer edge of the lens mounting flange on the body has broken off. This is a switch which senses when the lens is set to it's minimum aperture. Looking at the camera body, with the lens removed, it's at about the eight o' clock position on the outer edge of the body lens mounting flange.
1. is easily fixed:just fit the lens correctly. 2. Really needs a professional repair, but as you can get a used F60 (N60 in USA) for free these days (FreeCycle/Freegle) it's not worth doing: just fasten it permanently in the "activated" position. Do a bit of googling and you'll see what I mean.
I hope this has solved your problem, if so please rate my answer.
2/25/2010 11:14:28 PM • Nikon F60 35mm... • Answered on Feb 25, 2010
An error FEE Flashing comes when the camera is turned on
What lens?
If it's a CPU lens, remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts.
If it's not a CPU lens, you'll have to use it in the Manual (M) mode.
12/31/2009 10:29:53 PM • Nikon F60 35mm... • Answered on Dec 31, 2009
Hi I have a Nikon F60 35mm camera purchased second
http://safemanuals.com/annexe_INSTRUCTION%20MANUAL_NIKON_F60-_E.htm
Took the liberty o testing the download- a pop up comes askin you to rate the camera- just pop all the stars to where ever that unlocks the download button- definately works.
If that dont work or you dont trust the site i can always just email you it
11/6/2009 6:49:32 PM • Nikon F60 35mm... • Answered on Nov 06, 2009
2answers
A error 'FEE' Flashing comes when the camera is
Turn the aperture ring on your lens to F/22 or whatever is the highest number on the ring and try it.. If your lens doesn't have a ring, there is a broken switch on the camera.
10/18/2009 12:43:11 AM • Nikon F60 35mm... • Answered on Oct 18, 2009
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
8/18/2009 8:40:34 PM • Nikon F60 35mm... • Answered on Aug 18, 2009
Will not turn on and doesn't show the screen. Battery is hot.
Hi
E blinking is very popular symptom. Make sure your lens is set at F22. Your lens is not set to the smallest aperture (highest number). Turn the camera off, rotate the aperture ring so the largest number is lined up with the mark on the top, push the aperture lock tab, and turn the camera back on. The aperture ring is the one closest to the camrea body with numbers like 4, 5.6, 8, 11 etc on it. The largest number will be 16, 22, or 32 for most lenses. If it still doesn't work, turn off, remove & replace the lens, and recheck the aperture ring setting.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
6/17/2009 4:41:31 AM • Nikon F60 35mm... • Answered on Jun 17, 2009
My Nikon N60 shows an
This usually happens if the lens you mounted on it has an aperture ring and the aperture is not set to its smallest opening (the largest number)
4/24/2009 4:22:57 PM • Nikon F60 35mm... • Answered on Apr 24, 2009
Nikon F60 35mm SLR Camera Logo
26 questions posted
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
View Most Popular
Nikon Photography
  • Nikon Photography
Most Popular Question
f ee
  • Photography
