20 Most Recent HP Compaq W17q Monitor Questions & Answers
2answers
OCD LOCKED pops up at random
There might be signal issues from the source device; with intermittent problems, I recommend cleaning all the pins on both ends of the connectors and then removing and re-inserting the plugs a couple of times in hopes that it is a connection problem on one of the cable ends.
9/26/2017 1:47:31 PM • HP Compaq W17q... • Answered on Sep 26, 2017
manual
Can I connect a DVI to a Compaq W17q
No - it uses VGA 15-pin D-type connector according to the specs.
2/6/2013 7:10:12 PM • HP Compaq W17q... • Answered on Feb 06, 2013
My W17q monitor suddenly stops working
go into control panel , display setings and adjust display to never turn off
2/6/2013 10:08:38 AM • HP Compaq W17q... • Answered on Feb 06, 2013
Input not supported
The resolution your laptop is running in, or it's refresh rate is too high.Lower the resolution, or drop the refresh rate.It's native mode is 1440x900 at 60Hz
12/12/2012 8:23:10 AM • HP Compaq W17q... • Answered on Dec 12, 2012
How do I get the speakers on the monitor to work? Says I need to plug in headphones or external speakers for any audio to work.
It comes with a 3.5 male to male audio cable. You may have check you check volume settings for level and mute. treat as external speakers8_31_2012_1_33_33_am.jpg
8/31/2012 1:35:38 AM • HP Compaq W17q... • Answered on Aug 31, 2012
Why does the auto config please wait bubble continue to pop up on my screen?
Unusual approach to fix a problem, well done! saves expensive repair.
6/17/2012 10:55:54 PM • HP Compaq W17q... • Answered on Jun 17, 2012
The guide you told me to use did not have my model number W17q so I could not use any of the information.
Hello, try this link to the hp website where you will be able to view a user guide.http://h10032.www1.hp.com/ctg/Manual/c00881436.pdf If you want further info, then go to the main hp website:www.hp.comand select 'Support and Drivers' then on the next page, type in yourproduct 'W17Q' press 'search' then on the next screen scroll down and you'll see several options from which you can choose. Regards,nicam49
1/17/2012 9:37:18 PM • HP Compaq W17q... • Answered on Jan 17, 2012
0answers
2answers
Monitor goes on and off.
Hi, I am Steve, lets get started solving your issue.
With a monitor there a a number of things that may be causing the problem.
Firstly - if you unplug the monitor cable from the computer and start the monitor does it work: (should turn on and give an error message (no video input found or something similar). In this case the monitor is good and something is wrong with the computer.
If the monitor does not work then the monitor is at fault and it is likely the inverter is tripping the power out. that means a component is shorting or it is burnt out. These can be replaced but you are getting close to the cost of a new monitor to replace them.
Please let me know if the monitor is the faulty item. If it is not we can move onto the computer to see what is at fault or I can give you more details about repairing a monitor.
1/14/2011 1:50:51 PM • HP Compaq W17q... • Answered on Jan 14, 2011
My compaq w17q won't turn on. Help?
check if your compaq w17q power cable is properly connected to the AC adopter if not the change the power cable.
3/8/2010 9:08:36 PM • HP Compaq W17q... • Answered on Mar 08, 2010
Restart my computer like new
do a system restore on your computer
2/15/2010 2:41:10 PM • HP Compaq W17q... • Answered on Feb 15, 2010
No sound from speakers
Ok newer monitors come with a HDMI connector and would need a compatable HDMI video card that has the ability for sound. The older monitors have a 3mm plug like a head phone jack you can plug this directly into the GREEN portion of the sound card that is installed in your system!
Thanks please rate Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
5/2/2009 10:11:52 PM • HP Compaq W17q... • Answered on May 02, 2009
HP Compaq W17q Monitor Logo
28 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
get speakers monitor work says need
  • Computers & Internet
