20 Most Recent Casablanca Fan (88U33M) Ceiling Questions & Answers
Remote works but fan, lights dont
You need a new receiver. The light on the remote transmitter is only a battery indicator light. Call 1-8--715-0393 for part.
4/10/2015 2:48:42 PM • Casablanca Fan... • Answered on Apr 10, 2015
Replace light bulb
Above the top of the globe are some small screws with no slots for a screwdriver are 3 to 4 unscrew with your fingers or small pliers,hold the globe while you losen the screws.
4/23/2012 3:35:35 AM • Casablanca Fan... • Answered on Apr 23, 2012
The Casablanca 88U33M Scandia Ceiling
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3). Hook up is as follows:Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
7/4/2011 10:19:18 AM • Casablanca Fan... • Answered on Jul 04, 2011
Casablanca fan light works with remote but fan does not respond
Check white black power wire nuts or any wire nuts, to make sure the wires are all connected also cuz its wireless maybe check the yellow, gary, pink, red plug in's.
1/16/2023 8:01:13 PM • Casablanca Fan... • Answered on Jan 16, 2023
2answers
Casablanca stealth fan scraping noise
center of blade bracket mounts scrapping fan housing. Grasp blades and wiggle or shake them to make sure their not cockeyed. Turn it on then to check it.
8/23/2021 3:00:25 PM • Casablanca Fan... • Answered on Aug 23, 2021
I bought a used cascade 40" tower fan. it ran for a couple of hours and when I press the power button it wouldnt turn off so I unplugged it. now it wont turn on.
the switch is broken, so get the Fan repaired or replace the switch, with cord AC remove from the WALL AC power JACK.
6/9/2019 11:56:19 AM • Casablanca Fan... • Answered on Jun 09, 2019
I have oscillating fan was working and stop.I replace both capacitor.I have power to the motor but motor not work. My question is, where I cant find the new motor to buy? just the electric motor.
perhaps it may be a better choice to replace it. The cost of a motor if you could find one will exceed the value of fan.
11/21/2018 2:28:30 PM • Casablanca Fan... • Answered on Nov 21, 2018
Casablanca Fan (88U33M) Ceiling Logo
7 questions posted
Top Casablanca Fan Dryers Experts
Paul Bade
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
View Most Popular
  • Casablanca Fan Dryers
Most Popular Question
casablanca 88u33m scandia ceiling
  • Dryers
