20 Most Recent Bosch 2610948135 36 Volt Replacement Flashlight Bulb Questions & Answers
Bosch 36 volt flashlight bulb doesnt last
Here is what I have done for now. I was able to pick up a 24 Volt 10 Watt G-4 Base bulb at a local Boat USA store. So far so good. I had it running for 6 hours straight with no issues and still working.Finding a 36 Volt bulb replacement has been difficult and the bulbs don't last.
9/18/2016 2:53:34 PM • Bosch 2610948135... • Answered on Sep 18, 2016
I have a 4.5 V
Most of the Bosch flash lights have rechargeable batteries,means no need to replace battery.But still give the exact model number of your Bosch flashlight.As per that exact location of battery box can be identified.-----------Keep updated with details.Thanks.Helpmech.
2/9/2011 12:12:35 AM • Bosch Camping,... • Answered on Feb 09, 2011
Where can I find replacement parts for my rechargeable lantern?
It's great that you're looking to revive your rechargeable lantern! Here are some steps you can take to find replacement parts and ensure your lantern is in working condition:
  1. Check with the Manufacturer: Start by contacting the manufacturer of your rechargeable lantern. They may offer replacement parts for your specific model, including the light tubes. You can inquire about replacement batteries as well.
  2. Search Online Retailers: Look for online retailers specializing in selling replacement parts for lanterns and flashlights. Websites like Amazon, eBay, or specialized outdoor equipment stores may carry the replacement light tubes you need. Make sure to check if they ship to Canada.
  3. Visit Local Hardware or Outdoor Stores: Explore hardware stores, camping supply stores, or outdoor equipment retailers in your area. They may have replacement light tubes or similar products that are compatible with your lantern.
  4. Consider Universal Light Tubes: If you cannot find the exact replacement light tubes for your lantern, consider purchasing universal light tubes that fit the size and specifications of your lantern's sockets. Be sure to measure the dimensions of the sockets and compare them with the specifications of the replacement tubes.
  5. Test the Battery: Before purchasing replacement parts, it's a good idea to test the battery to see if it still holds a charge. If you have a compatible charger, you can try charging the battery and observing its performance. If the battery no longer holds a charge or shows signs of leakage, you'll need to replace it.
  6. Inspect for Damage: Since the lantern has been in storage for several years, carefully inspect it for any signs of damage or wear, especially around the battery compartment and electrical components. If you notice any corrosion or damage, it's best to address those issues before using the lantern.
By following these steps, you should be able to find replacement parts for your rechargeable lantern and get it back into working condition. If you encounter any difficulties, don't hesitate to contact customer support or seek assistance from a local retailer.
4/16/2024 9:58:57 PM • Camping,... • Answered on Apr 16, 2024
What amp and volt charger do you need to charge the tw-308 taser flashlight
Not sure of the legality of the secondary function! https://www.google.com/search?q=tw-308+taser+flashlight+charger ..
4/9/2024 11:03:17 PM • Camping,... • Answered on Apr 09, 2024
La-Z-Boy Slumber air mattress. How to repair a leak in one please?
Question edited for clarity, correct order and spelling of maker. Duplicate question deleted, Refresh page to see your question. Repairing leaks is easy if you can find it and depending where the leak is? Information and videos in the link https://www.google.com/search?q=La-Z-Boy+Slumber+air+mattress.+How+to+repair+a+leak ..
4/9/2024 11:00:55 PM • Camping,... • Answered on Apr 09, 2024
I have Illumibeam Lantern, Crank Up. It has a plug in the wall don't know how it work. I plug it in, no lights no nothing.
This one? https://www.ebay.com/itm/335145703247 They are a bit of a gimmick, and of course are made for $2 in China. The way they work is that they contain a small rechargeable NiMH battery. You can charge it via the wall adapter, or you can turn the crank which operates a small generator to charge the battery. It is likely that you can't run it directly from the mains, but it should light when you remove the charging cable and switch it on. ..
3/21/2024 5:05:42 PM • Camping,... • Answered on Mar 21, 2024
2answers
Lost assembly instructions for my Stockman Wimmera 8 Person Tent. Can you help me? ThankYou!
It's a bit old/dated and a few holes...but think this should do the trick: 9c803efb-edc7-4048-b15a-09c281fa2915.jpg
3/8/2024 4:33:04 AM • Camping,... • Answered on Mar 08, 2024
BLACK+DECKER SL3WAKB: Compact 300 Lumen LED Spotlight Flashlight. How to replace bulb in flashlight SL3WAKB
It carries an LED Module, so they aren't like replacing a halogen bulb, you have to replace the whole module with the LED. Just replace the whole lamp for 10 bucks!
BLACK+DECKER SL3WAKB: Compact 300 Lumen LED ...
AZ Electronics https://azelectronics.ca > products > sl3wakb-bla-compa... BLACK+DECKER SL3WAKB: Compact 300 Lumen LED Spotlight Flashlight · LED delivers bright beam of light · Compact and lightweight design · Power saver setting to ... $9.99 · ‎ In stock ..
3/5/2024 4:41:29 AM • Camping,... • Answered on Mar 05, 2024
How do l replace batteries in a vintage Dorcy 41-1015 dual spotlight?
It looks like you unscrew the plastic lens and remove the bulb and reflector like the old Pifco versions. https://www.google.com/search?q=Dorcy+Focusing+Lamp+Dual+Spotlight%2F+Model+41-1015+replace+battery ..
2/14/2024 12:38:48 AM • Camping,... • Answered on Feb 14, 2024
2answers
Do you need special hiking shoes for going on long walks?
Whether or not to buy hiking shoes really depends on what kind of walking you plan to do and how often.Hiking boots are helpful for rougher terrain and for gripping. If you plan to mostly walk on flat ground, you can consider getting good walking shoes instead.
1/25/2024 4:10:25 AM • Camping,... • Answered on Jan 25, 2024
What is camp furniture?
Camp furniture is items like tables and chair that are madeout of a durable material, are light and can be folded up and packed.
1/10/2024 2:37:49 PM • Camping,... • Answered on Jan 10, 2024
2answers
Propane lantern burns yellow light not bright white while we are fishing
Doesn't that suggest a blocked nozzle, requiring first a quick probe with a "pricker"?
12/17/2023 10:42:37 AM • Camping,... • Answered on Dec 17, 2023
Nebo Big Daddy flashlight.
Question moved from Cars and Trucks category to Flashlights. Apparently not easy if you use the 3 x AAA battery cartridge. Unscrew the base. https://www.amazon.com/ask/questions/Tx1DKW5P7LJ9IXV/ Sometimes they will take a rechargeable 18650 instead. https://nebo.acgbrands.com/en_US/lights/replacement-batteries.html https://www.arcade-electronics.com/v/vspfiles/nebo/120REDLINE%20Big%20Daddy%20User%20Manual.pdf ..
12/15/2023 1:01:54 AM • Camping,... • Answered on Dec 15, 2023
2answers
I need a new bottom for the Tinkerbell Lantern.
There are no parts for them. You just buy a new one. Or you might have someone 3D print you one. https://www.google.com/search?q=tinkerbell+lantern ..
11/23/2023 12:27:34 AM • Camping,... • Answered on Nov 23, 2023
How to open the coast px45 flashlight
Purportedly, twist the tailcap counter-clockwise.
11/1/2023 7:31:49 PM • Camping,... • Answered on Nov 01, 2023
How do you take apart a bushneell 600 lumens flashlight
Taking apart a flashlight, including a Bushnell 600 Lumens flashlight, may not be recommended, as it can void the warranty and potentially damage the device. However, if you have a specific need to disassemble it, here are some general steps to follow: 1. Remove the batteries: Ensure the flashlight is turned off, and remove any batteries to prevent any accidental activation or electrical shock. 2. Look for screws or openings: Most flashlights have screws or openings around the head or tail cap that allow access to the internal components. 3. Unscrew components: Use the appropriate screwdriver or tool to remove any visible screws holding the flashlight together. If there are no screws, try gently twisting and separating the parts. 4. Be cautious with wires: If your flashlight has internal wires and circuitry, be extremely careful not to damage them while disassembling the flashlight. 5. Document your steps: Take photos or notes as you disassemble the flashlight to help you remember
10/24/2023 4:55:23 PM • Camping,... • Answered on Oct 24, 2023
COASTHP7 flashlight bulb replacement ?
Try contacting COAST directly. I think they give a Lifetime Warranty on their flashlights. Ask for the repairs department. You never know, they might do it for you under the warranty. There's no harm in asking them.
10/10/2023 9:20:36 PM • Camping,... • Answered on Oct 10, 2023
2answers
How do chemical hand warmers work?
I actually just did a lesson on this with my students. When the chemical hand warmer is removed from the outer packet and exposed to oxygen, it produces an exothermic chemical reaction, which is a reaction that gives off heat. The result of this reaction is iron oxide or rust.
10/4/2023 9:30:15 PM • Camping,... • Answered on Oct 04, 2023
3answers
What are the benefits of sports camps?
The physical benefits kids achieve with athletic activity, such as cutting the risk of obesity, diabetes, heart disease and social and psychological benefits of getting involved in athletics while in school. The ratio of coaches to athletes is always a plus. Most youth sports only have money for one coach, but professional camps like organizers have a skilled coach for playing and training children in Camps for Youths in your Area. At camp, the athletes will be exposed to several coaches with a variety of coaching styles.
9/23/2023 4:27:13 PM • Camping,... • Answered on Sep 23, 2023
Bosch 2610948135 36 Volt Replacement Flashlight Bulb Logo
1 questions posted
Top Bosch Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Bosch Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Camping, Backpacking & Hiking
Most Popular Question
bosch 36 volt flashlight bulb doesnt
  • Camping, Backpacking & Hiking
