20 Most Recent Stanley 5 Watt Led Waterproof Rechargeable Spotlight Camping Hiking Flashlight Questions & Answers
How do I open a stanley fatmax 5watt waterproof rechargeable spotlight without ruining the watertight seal ?????
It may not be possible if seal is stuck to either surface. Best just open it first. If seal breaks, then either replace the seal if one available or replace the unit
1/10/2018 7:55:22 AM • Stanley 5 Watt... • Answered on Jan 10, 2018
How do I switch from strobe to constant light?
Depress the switch until light goes on but does not click on and then release just a little and depress again, light should switch to solid if it does than depress button all the way until it clicks on. If there is a high and low setting on the torch than make sure you are in high.
5/18/2013 9:37:58 AM • Stanley 5 Watt... • Answered on May 18, 2013
My Stanley Satellite flashlight wont charge...when I plug it in the lights dont come on or anything...
That unit comes with 2 chargers and you should try them both to see if it is the charger or the battery system in the actual light.
4/19/2020 2:29:03 PM • Stanley Camping,... • Answered on Apr 19, 2020
https://www.youtube.com/watch?v=XPBSSSBn2PU
  1. There is one battery in each leg unscrew the bottom cap. ...
  2. It takes three AAA batteries, and the slot for each one is actually the legs - simply screw off the cap at the end and slide the battery in, and screw it back on.
4/19/2020 10:50:22 AM • Stanley Camping,... • Answered on Apr 19, 2020
How do I replace a LED light bulb in a Stanley MaxLife 369 Tripod Flashlight? 1 of 6 bulbs stopped lighting.
Contact Stanley if it's still under warranty:
https://www.stanleyblackanddecker.com
4/9/2019 1:48:35 AM • Stanley Camping,... • Answered on Apr 09, 2019
How to change the light on stanley 3 in 1 flashlight
no idea what model you have. check out the manufacture website good luck https://www.6ya.com/mrmmike
3/2/2019 8:52:02 PM • Stanley Camping,... • Answered on Mar 02, 2019
Disassembly of Stanley MaxLife 369 flashlight
Unscrew the caps on the bottom of the legs - each leg has 3 AA batteries
10/22/2017 4:10:00 AM • Stanley Camping,... • Answered on Oct 22, 2017
Changing batteries on stanley 77 153 how do i access battery compartment
Product manual is found at http://www.otelo.fr/waroot/OTFR/fr_FR/attachments/notice_instruction/3859_NI_47201300.pdf. See page 4 of 28, titled "Power" on how to change battery on this device.
7/21/2017 1:18:10 AM • Stanley Camping,... • Answered on Jul 21, 2017
Stanley ultra bright led spotlight SL5W09L will
I am having the same problem with one of mine. If I turn it down to low it will stay on. (press and hold the down arrow on the back of the light after you turn it on till it beeps, then it works forever).
2/19/2016 6:36:55 PM • Stanley Camping,... • Answered on Feb 19, 2016
How do I get my Stanley 2m series spotlight to Charge?
To take the charge the inbuilt battery must be functional. Once the battery goes bad you will be unable to charge the unit or it will take a small charge and die rapidly thereafter. You may or may not be able to change the battery. It depends on the manufacturer of the product so you should consult the instructions that came with the item if you still have them.
11/28/2015 11:20:07 AM • Stanley Camping,... • Answered on Nov 28, 2015
Need a replacement charger & instruction
I need a replacement cord to recharge my Stanley Bar Flex, Model #BF0109S, 6Vote DC-600mA. Is this something I can purchase from you? I can be reached at 207-395-4721 or you can email me at: [email protected] you for your prompt attention.Jane W PerkinsEast Winthrop, ME 04343-0373
8/12/2015 6:30:39 PM • Stanley Camping,... • Answered on Aug 12, 2015
Stanley flashlight keeps blinking like a strobe light how can I fix it
I assume it is an LED flashlight (you did not say). Cheap Chinese-manufactured LEDs will flicker in this way when they go bad. The condition is not repairable... you will need to replace the flashlight. (Save the batteries.)
5/11/2015 6:33:40 PM • Stanley Camping,... • Answered on May 11, 2015
Stanley 5 Watt Led Waterproof Rechargeable Spotlight Camping Hiking Flashlight Logo
5 questions posted
Top Stanley Camping, Backpacking & Hiking Experts
ZJ Limited
ZJ Limited
Steve Pack
Steve Pack
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Camping, Backpacking & Hiking
Most Popular Question
open stanley fatmax 5watt waterproof
  • Camping, Backpacking & Hiking
