20 Most Recent
Holmes Products Holmes HAOF951T-U Blizzard 1 Touch Power Fan Wall Mount Questions & Answers
Cleaning the fan
There are 4 small screws in the rim between the ribs accessible from the back. Remove the screws and the cover will come off.
Fan does not osculate all
The worm hear or drive gear that are mainly made of plastic has stripped out. Just don't use the revolving ossulator option any longer
I have a table model
What happens is the bearings in these are not all that good, usually that noise is that bearing sounding out.
So YES unfortunately it indeed does mean you need to buy a new one...
Wire box fan direct bypass switch
Am I the only one reading that the OP is asking about a box fan.....never seen lights on a box fan...
I'm also trying to bypass the 3 speed knob on my box fan. Is it possible? I ask because preliminary testing of holding wires to each other turned the blade but began getting hot and with enough time I'm sure would've been a pretty nice fire.
I have a pedestal
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Ht38rbu repair noise
Take front of the fan cover off hold the back of fan the push and pull out on fan blades from the center. If blades move in and out .The bearings on motor shaft worn out. If no movement try to blow out the motor with compressed air reassemble then try.
