20 Most Recent Gateway GP PC Desktop Questions & Answers
Where is the power supply on gateway 300s
eb3501a5-f045-4c8d-97a6-99fa6cf99c7a.jpg Top of case.
7/22/2014 1:16:25 AM • Gateway GP PC... • Answered on Jul 22, 2014
Has 3 beeps when cpu is turned on
This is a standard IBM (the original PC), but there is a slight chance your is different.1 long, 2 short beeps Display adapter problem3 long beeps keyboard
8/29/2012 12:15:15 AM • Gateway GP PC... • Answered on Aug 29, 2012
Gp5-580 computer spec
Try Gateways support site and look for the specs.Get onlineand got to www.google.com In the google search box type: "GatewaySupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Documents that will show you the Specs.
5/5/2012 1:02:20 AM • Gateway GP PC... • Answered on May 05, 2012
My computer GP is very low. how can i get it more
you have to do this four steps:1. upgrade your memory2-click start , then run in run type msconfig , then start up then disable all3.click service , then hide microsoft service then disable all, then apply then restart the computer.if it doesn't let me know i will give an other tip
3/12/2012 4:53:59 AM • Gateway GP PC... • Answered on Mar 12, 2012
Cd/dvd rom not working i
open your pc shutter and plug the both cables of cd dvd rom the data cable and the power cable or replace it with the new one and check on bios that these are detected.
7/17/2011 9:47:33 AM • Gateway GP PC... • Answered on Jul 17, 2011
Disk write error unable to write to disk drive C:
The hard disk is dying - replace it and reinstall Windows by using the recovery cd that came with the pc when you bought it.
4/3/2011 2:52:18 PM • Gateway GP PC... • Answered on Apr 03, 2011
Hi, I have a Gateway GP6-566C
Most desktops will check the floppy drive when starting up anyway regardless of what setting is in the bios, try to look for any commands required for boot selection when you boot up...I have to hit TAB while booting up to select to boot from CD.
Let me know how you get on
3/21/2011 7:03:47 PM • Gateway GP PC... • Answered on Mar 21, 2011
Old computer gateway gp6-400c i reinstalled win
Go to Gateway Support website and type your serial number. All drivers for this model will be listed.
http://support.gateway.com/support/drivers/dlcenter.asp?cmpid=topnav
7/21/2010 2:50:21 PM • Gateway GP PC... • Answered on Jul 21, 2010
Quisiera saber el tipo de memoria ram que usa mi
¿qué quieres hacer con este problema? Sírvanse ampliar la información.
what do you want to do with this problem? please elaborate further.
hope the translator is correct...
3/25/2010 1:35:46 AM • Gateway GP PC... • Answered on Mar 25, 2010
Gateway GP (Micro ATX cel gp6-500c)
A fesh restart is in order the if these crash reinstall windows if that dont shore it up we need to troubleshoot more clikc on ask expert a question or chat with a expert we will be here to run you through this issue and get you up and running in no time.. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
5/15/2009 6:43:01 AM • Gateway GP PC... • Answered on May 15, 2009
I need a cpu fan what size does it take
It goes by which socket you have. I am an Intel connoisseur so my knowledge ends with Intel PCs.
If your processor is an early Intel Pentium 4, you will want a socket 478 CPU cooler.
If your processor is a late Intel Pentium 4 or Intel Core 2 Duo/Quad (~2ghz+) you will want a socket 775 CPU cooler. Luckily this socket is still in wide use and many can be found locally or online.
If your processor is an Intel Core i7, you will want a socket 1366 cooler.
Just go to a local PC store and ask for an LGA478, LGA775, or LGA1366 CPU heatsink.
4/11/2009 3:17:50 AM • Gateway GP PC... • Answered on Apr 11, 2009
I did re installation and
go to internet search for gateway website find the exact model and download the drivers
2/24/2009 9:10:49 AM • Gateway GP PC... • Answered on Feb 24, 2009
I have the application SuperSU the free edition on my phone and everytime I try to use it to root my phone forwards me to an address on Chrome the simply says 502 bad gateway
you can use kingroot to root your phone. and some root apps might harm yor os i suggest you not to root your phone
3/1/2024 4:28:21 PM • Gateway... • Answered on Mar 01, 2024
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor. The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port. I hope this helps. Cindy Wells
1/18/2024 10:32:24 PM • Gateway... • Answered on Jan 18, 2024
I have a gateway Zx4931 and the power button is not working. Do I need to replace the power button or can I reconnect the wires?
Re connecting the wires may work without issues.
12/26/2023 5:46:39 PM • Gateway... • Answered on Dec 26, 2023
Do i need a driver for old gateway gmax2000 speakers connected to an old acer-based home built pc my nephew gave me?
No you don't need a driver. These are very plain powered speakers that come with a mains adapter and a lead with a 3.5mm stereo jack at both ends. Plug one in the speaker and the other into the headphone jack on the front or the speaker socket on the back which will either be a socket on the motherboard, or if your son put a sound card in the computer, it will be in a sound card. If it doesn't play straight away, go into Settings - Audio and make sure the sound card or the On-Board Audio is enabled. This shows the cable https://picclick.com/Vintage-Gateway-2000-ACS41-Altec-Lansing-Multimedia-Computer-314990339798.html#&gid=1&pid=1 More here https://www.google.com/search?q=gateway+gmax2000+speakers ..
11/29/2023 12:20:06 AM • Gateway... • Answered on Nov 29, 2023
WATTS REQUIRED FOR GATEWAY LAPTOP NV55C
110 watts for the power supply.
11/21/2023 1:16:48 AM • Gateway... • Answered on Nov 21, 2023
Wiring diagram for LX6200-01
10/30/2023 11:58:58 PM • Gateway... • Answered on Oct 30, 2023
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do. First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button. Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button. Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation. I hope this helps!
3/14/2023 5:41:18 PM • Gateway... • Answered on Mar 14, 2023
I have a Gateway Laptop that on startup only goes to the configuration screen. It won't boot Windows at all
They deleted the Operating System by deleting their own stuff Docs, images, Saved Links etc. and also everything in Windows System probably in spite. You need to reload the operating system (Win 11) from fresh. Charge them from their final pay check, or ask IT to do it.
3/1/2023 1:19:14 AM • Gateway... • Answered on Mar 01, 2023
Gateway GP PC Desktop Logo
Popular Tags
14 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
power supply gateway 300s
  • Computers & Internet
