20 Most Recent
HP Compaq dc5000 PC Desktop Questions & Answers
Power-on password hp compaq dc5000
RTM yet< here I will read it to you.
learn the fixya is not HP and only the real HP can validate ownership. never will fixya, sorry.
be like asking chevy to fix a Ford .
did you know HP has forum ? one of the larger PC maKERS ON EARTH, No less.
the PC is 14 years old now. be time for new RTC coin cell
if the cell is bios goes nuts, and maybe password rests
ive never seen one last 14 long years yet, hint hint
page 3-13 (jumper) amazing things called books
http://h10032.www1.hp.com/ctg/Manual/c00093003
Ethernet drivers
http://h20566.www2.hp.com/portal/site/hpsc/public/psi/swdHome/?lang=en&cc=us&sp4ts.oid=403750 pick your installed OS and then download the driver.
Don't know how to download this information to a
use the browser and download the browser will be indication with some arrow indicating that download is executing. When the download is done. you must open the site where is located normally in your documents/download open and click to send the USB with the name D or E, etc. and ready.God bless you
Cd drive won't open
Sometimes a bad disc can cause this. You can stick a paper clip in the hole by the eject button to open it. If it isn't opening with the button though I'd replace the drive.
Continuous beeps, no display
Usually continuous beeps from an hp means the power supply unit is acting up.It is not switching on the power required for the mobo to boot up. Could also be ram prob but then the beeps tend to have a break b4 repeating. try booting with HDs disconnected. If no result. clean rams teeth with a eraser and try again. If still beeping try another power supply unit. It does not have to be identical similar will do. Once you isolate the cause of the non boot you can decide if you want to do a patch work repair or fix with originals
When i turn on my
It sounds like the power supply is failing. This computer has an odd size power supply. You could try another power supply from another computer and see if it boots up just connect it from the outside of the case temporarily . If it is the power supply you could remove the power supply to measure it and search online for the correct one. I just did a Google search and there were alot of option to choose.
Thanks for using FixYa
My problem is i can't
can you state the devices youre trying to connect, such as pc to modem, pc to router, pc to another network, also need to know what OS you are using, lastly any error messages, thank you
