20 Most Recent Motorola Mobility Defy Mini XT320 Black Android 2.3 SIM Free / Unlocked Questions & Answers
Disable the screen lock I initiated
From the home screen, press the Menu button (1st one on the left with 3 bars) then tap settings, then location and security, then set up screen lock, pattern. There you should be able to turn it off/on
4/30/2019 1:05:15 AM • Motorola... • Answered on Apr 30, 2019
2answers
Locked sim card
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
1/20/2016 7:54:27 PM • Motorola... • Answered on Jan 20, 2016
MY PHONE WONT DISPLAY NUMER OF INCOMING CALLS ?
On all calls or certain calls? Have you contacted your service provider to see if caller id is off? Mark Motorola Support
3/11/2015 1:25:59 AM • Motorola... • Answered on Mar 11, 2015
I need to fix my phone
Hi DEFY Master Reset Factory Data Reset Mark Motorola Support
1/5/2015 2:03:27 PM • Motorola... • Answered on Jan 05, 2015
MY MOTOROLA KEEPS SAYING NO NETWORK COVERAGE
Lilian- Have you contacted your service provider to ensure your phone is provisioned properly? Does this happen in all locations or only certain areas? Mark Motorola Support
8/27/2014 11:09:21 PM • Motorola... • Answered on Aug 27, 2014
I set my phone back to factory settings & now I can't reinstall my barclays bank or barclaycard apps
Sounds like it is pre-installed. have you tried resetting again? Maybe you can find a copy of the app online and then sideload the apk file by turning on Unknown Sources. Please ensure you get the app directly from Barclays though.
6/2/2014 3:28:42 AM • Motorola... • Answered on Jun 02, 2014
Motorola mini defy wont load only motorola shows
How to hard reset: Warning! All data will be lost! 1.Power off your phone 2.Press together volume up + volume down + power button until recovery menu appears 3.Select "recovery" with volume buttons and press camera button to confirm 4.Press home button when Android logo appears 5.Select "wipe data" with volume buttons and press camera button to confirm 6.Select "yes" and press camera button to confirm 7.Wait until format ends 8.Select "reboot" and press camera button to confirm 9.Wait until phone restarts That's it! - See more at: http://factory-reset.blogspot.com/2013/09/motorola-defy-mini-xt321-hard-reset.html#sthash.eUfAgbLd.dpuf
6/2/2014 2:58:13 AM • Motorola... • Answered on Jun 02, 2014
Motorola XT320 wont turn on
This happened to me! I still can't fix it but I have some advice to help you! You will need to hard reset it here's how 1) backup everything on a pc 2) turn on phone 3) press Vol+ and vol- at the same time then press pwr. 4) that should load up recovery mode 5) use vol keys to navigate and camera key to select. 6) pick reset 7) if it comes up, press ful reset! 8) accept warning 9) wait for it to reset then reboot 10) that should be it. 11) if that doent work please take your phone to a tech repair shop
11/23/2013 5:33:20 PM • Motorola... • Answered on Nov 23, 2013
0answers
Invalid battery
Be the first to answer 5/4/2013 8:45:02 AM • Motorola... • Posted on May 04, 2013Be the first to answer
tip
Sim Network Unlock Pin Motorola
How to enter my Unlock Code on Motorola ?
Model : All Motorola 1 - Switch ON your phone with a not allowed SIM Card, 2 - Phone show "Enter Special Code", 3 - You can now enter the Unlock Code we send to you. WARNING : If one of theses messages appear : - "Contact Service Provider" - "Tampert Alter" - "Wait before enter special Code" - "Contact Service' It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
https://www.unlockbase.com/faq/en/Q_47.html
0answers
Mp3 download
Be the first to answer 4/11/2017 8:51:03 PM • Motorola... • Posted on Apr 11, 2017Be the first to answer
4answers
HOW TO GET A PIN CODE IN RAN ONLINE PH
how to retrieve my pin code in ran online
4/23/2024 5:38:00 AM • Cell Phones • Answered 10 hours ago
2answers
What is the difference between CEH V8 and CEH V9?
The difference between EC-Council's Certified Ethical Hacker v8 and the new Certified Ethical Hacker v9 is not the exam format, but the content itself. People seem to assume that since EC-Council updated the certification, the exam must be brand new. This isn't the case. In order to obtain the new CEH v9 certification, you do not need to study for and pass a brand new exam with new objectives and format. The test has the same format, is identical in size, and has the same amount of questions. There are only two things that changed. CEH V9 EXAM FORMAT AND BREAKDOWN The aforementioned v9 exam follows the same format and percentage breakdown of questions as v8. For example, the section on security will still take up 25% of the exam, while the section on tools, systems and programs will take up 32% of the exam. The full breakdown of the exam is visible on our . The Exam Details are as follows:125 questionsTo pass you need a score of 70%Maximum of a 4 hour durationMultiple choice formatHOW TO PASS YOUR CEH EXAM If you are studying v8 exam materials, you are not automatically going to fail the v9 exam. The test is updated, not revamped. This means there might be a handful of questions you may not necessarily have studied in depth for, but if you studied at all, you will have some familiarity with the new questions. The new questions are not on brand new material, they are more in-depth questions on topics that have become more relevant in the cyber security world over the last eighteen months. So you can still pass v9 studying v8 material.Should I still take CEH v8 Exam? However, if you study v8 materials you can still take the v8 exam. EC-Council has not retired the exam yet. So if you are not comfortable with the idea of taking an exam that you may not know 10-15 "new" questions, then don't. The only problem with this is that once the v8 certification does retire you will eventually need to take v9. Why prolong the inevitable then?Will I need to take the CEH v9 exam? If yes, then when? The test is updated on a rolling basis. This means that occasionally EC-Council adds new questions to the exam without updating the entire certification. The fact that v9 is now available means that there are new and updated CEHv9 study materials with a new focal point to deal with the always progressing world of IT.THE DIFFERENCE BETWEEN CEH V8 AND V9 With the update to the courseware, the exam covers certain questions differently. These questions focus on topics that are becoming more prevalent in the world of cyber security and IT. The key differences are:V9 focuses on cloud computing more than v8 did and dives into best security practices for dealing with cloud computing attacks.V9 covers mobile security and tablet computers and you must understand how to perform hacking techniques on these devices.v9 addresses new vulnerabilities in cyber security such as, Heartbleed, Shellshock, and POODLE. CEH v9 vs v8 What New on the Certification Exam TechRoots
4/22/2024 6:43:13 AM • Cell Phones • Answered Yesterday
I'd like to update my stereo in my Citreon C3 (2007) to a double din header unit.
Let's explore your options: Double DIN Stereo Upgrade Kits: There are aftermarket double DIN stereo upgrade kits available specifically for Citroen C3 (2010-2016) and Citroen DS3 (2010-2019) models. These kits include everything you need for a seamless installation, including a fascia kit, plastic brackets, screws, blanking buttons, steering wheel control interface, antenna adapter, USB and AUX retention leads, and a universal patch lead. The installation process involves removing the original single DIN radio, fitting the new plastic frame and fascia around the double DIN radio, and connecting the wiring harness and other components. These kits are designed to retain steering wheel audio controls and other features. Keep in mind that dashboard modifications are required, so professional installation is recommended. Connects2 Adapters: If you choose an aftermarket stereo that isn't specifically designed for your Citroen C3, you can use a Connects2-style adapter to convert a compatible aftermarket stereo to control the screen above the radio (date/time, etc.) 3. This way, you can still access essential information. For example, a Double DIN Android Auto-compatible stereo like the JVC KW-M560BT could fit in the space after removing the cubby and factory radio. Some C3 models have a dash-mounted CD autochanger or other features that need careful handling during the upgrade. Citroen C3 2009 Aftermarket radio upgrade - Double DIN (citroenc3owners.com) Professional Installation: Consult with a car audio installer or technician to choose the best solution for your specific Citroen C3 model. Regardless of the approach you take, professional installation is highly recommended.
4/20/2024 10:12:16 PM • Cell Phones • Answered 2 days ago
Kyocera DIGNO Dual WX04K. HOW TO RESET KYOCERA WX04K DUAL DIGNO please?
How to hard reset KYOCERA DIGNO WX04K WILLCOM
GSM Hosting https://forum.gsmhosting.com > vbb > how-hard-reset... Feb 24, 2016 - Ihave solution turn off mobile than holde both volume keys and connect usb i will install adb drivers and than install kingoroot in pc and ... Missing: DUAL ‎' Show results with: DUAL
How To Do A Hard Reset On Kyocera DIGNO Dual WX04K
Tweakdroid https://tweakdroid.com > hard-reset > kyocera-digno-d... Nov 28, 2021 - To start, go to the Settings menu of your Kyocera DIGNO Dual WX04K; Find the factory data reset option. · Click on Erase all data. ; Turn off the ... ..
4/20/2024 7:30:08 PM • Cell Phones • Answered 2 days ago
Necesito desbloquiar mi telefono.
4/18/2024 4:28:55 PM • Cell Phones • Answered on Apr 18, 2024
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue: Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists. Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery. Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process. Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues. https://www.manua.ls/stanley/bc15bs/manual If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM • Cell Phones • Answered on Apr 18, 2024
2answers
HiSense F22. I forgot my parent access code, my daughter's phone is locked.
Are you sure you aren't the daughter trying to get around the code? The onus is on your daughter to remember her access code. Your parental code allows you to make restrictions to the phone.The only way to fix it is by doing a Factory Reset. Scrub it clean and start again.https://www.google.com/search?q=hisense+f22+hard+reset..
4/18/2024 6:34:42 AM • Cell Phones • Answered on Apr 18, 2024
Motorola Mobility Defy Mini XT320 Black Android 2.3 SIM Free / Unlocked Logo
27 questions posted
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Cell Phones
Most Popular Question
phone wont display numer incoming calls
  • Cell Phones
