20 Most Recent
Thane Q-BBQ Grill Questions & Answers
One side won't light.
Spiders love the smell of the gas and sometimes crawl into the small tiny orifice and fill with web where the pilot lights since that is the area where the first part of the gas enters the burner-try using a needle or straight pin to clean
Instruction Manual for Thane Q-grill.
go to this site http://www.thane.com/manuals/manuals.php then scroll down to the Thane Q-BBQ Grill manual, select it and it will open in PDF formate so you will have a free instant manual.. if this helps please rate me and let me know..thanks and good luck!
I need replacement regulator
For any type of answer, you will
have to provide a product & some
details of what you need to know,
& ask the question again & get it
into the correct category
Do you know where I can get some thane barbeque
I have 3 BRAND NEW packages of the drip trays! By the time they arrived, the grill had died and I gave up on getting help! If you contact me through Facebook, maybe we can come up with a way to get them to you if you still need them...
Knob stuck
if the knob is stuck remove it and spray the valve heavily with wd-40 while pressing the stem in and out and in and out and in and out and slightly wiggling to turn. If the inside is not broken this will remove the built-up dirt that does not allow the valve to turn. If this does not help then the inner lubricant has been over-heated and stuck in the ball-valve. it cannot be fixed, only replaced.
