20 Most Recent
Vodavi 30-BUTTONVODAV XTS Telephone Questions & Answers
Vodavi mailbox password reset
First, access your voice mailbox (press VM button & enter your password)
When you hear you have ??? messages, Press 7.
You will be prompted for another password (the Admin default password is 2275)
Press 2 administer mailboxes
Press 1 to reset mailbox password then follow the instructions. It will tell you what the current password is to the mailbox you select and you have the option to keep it or change it.
10/22/2014 8:07:44 PM •
Vodavi...
Answered
on Oct 22, 2014
I need to know if the vodavi 30 button part number
No. It's a programming item and a code or softkey.
The user connects the modular headset to the handset jack on
the telephone leaving the handset in place. The ON/OFF
button on the Digital Telephone is used to initiate and end calls
while using the headset.
To activate Headset Mode:
Dial [634] on the dial pad,
-or-
Press preprogrammed HEADSET MODE button. LED lights
steady.
To deactivate Headset Mode:
-or-
Press the preprogrammed HEADSET MODE button. LED
extinguishes.
While Headset mode is active, the ON/OFF button
activates the headset and disables speakerphone
and intercom call announce operation at your
station.
To install the headset, see the Installation Manual.
Station must be programmed in database
programming for headset operation before the
flexible button can be programmed.
Carl
2/5/2013 1:46:43 AM •
Vodavi...
Answered
on Feb 05, 2013
The vodavi phone screens are blank or they have crazy script
Wow, I am a repair tech. Power the whole system down. You will see a set of dip switches on the main CPU once you pull the cover off. The CPU is the first card to the left. Flip switch 8 in the off position. Trun system back on. All your first set of phones should come back on. Now turn it all back off and turn that switch back on. Your are factory default. Your fun has only just begun. Email me for more info.
[email protected]
6/24/2009 4:20:23 PM •
Vodavi...
Answered
on Jun 24, 2009
Trouble with call forwarding to our multiple lines & voicemail
It's not and they're idiots. The hunt sequence you describe CF-No answer is part of their arrangement, probably Centrex/Centranet.
This is one of the sloppiest setups they can possibly give you, but it relates to destinations for CF busy and CF no answer. Get someone who has a clue and tell them to adjust the time on the No Answer part, or, better yet, give you something that really works.
Carl
6/1/2009 10:50:04 PM •
Vodavi...
Answered
on Jun 01, 2009
Changing time on xts phone
I am a Vodavi tech. Any questions you have, Email me
[email protected]. On this problem, go to the front desk and without picking up the handset, dial 692. Enter YY/MM/DD/HH/MM
3/21/2009 5:34:52 PM •
Vodavi...
Answered
on Mar 21, 2009
