20 Most Recent
Thermador DW44Z Built-in Dishwasher Questions & Answers
Fault Code F
Code F is a fill fault issue either to little water is going into the unit or to much water is going into the unit you would have to check the water fill valve as well as the float switch to determine if either of these are your fault. You can test both with a multimeter the solenoid on the top of the water valve should be tested to assure that power is going to the valve. Also assuring that the float switch is not stuck in an open or closed postion as well you can also perform a continuity test on the switch with the power turned off at your electrical breaker. If you have any further questions message me back Thanks Rick
Will not drain
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
How do I turn off
Welcome to
FixYa.
To perform the requested task, do as follows...
Hope that answers your question and resolves your "annoyance"
lol...I understand :)
Thank you for choosing
FixYa today.
Please take a moment and rate the info provided for you here and let me know if i can assist you in any other matter. Good luck.
Regards,
Macmarkus :)
The dishes do not come
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Hope this helps......
Daniel
I have a Thermador DWHD630GCM
Hi
Please check if anything is clogged or not and try cleaning
the pump filter, if the issue returns then you should replace the pump. Hope
this helps...please post back for further assistance.
Daniel
