20 Most Recent
Konica Minolta PagePro 1400 Laser Printer Questions & Answers
Add printer driver failed
It will be ideal to reset the PC. so remove your printer from the PC and uninstall the printer driver software. Now reinstall the printer driver software and connect the Printer to be detected which will be detected as a new hardware and installed. Check printer properties to see the ink levels.
Konica minolta page pro 1400w printer driver
You have to use the latest versios of the driver, just to be sure. For Vista (32 bit) the latest version is v1.2.118.0 and for 64 bit the latest version is v1.3.301.2. If you don't have it, I can share it with you.
Refilled the toner and changed the chip. Error
bad news the manufacture is smart with those chips you will 10 two 1 have to purchase the correct cartridges brand new from a konica minolta supplier trust me we have tried to do this the rechipping hardly ever works especially when the machines have the latest firmware loaded
My konica minolta pagepro 1400w just stopped
you need to let the computer recognize the printer and that by reinstalling the driver and the software but you need to delete the old one first then reboot and then install it again
Is it compatible with mac
On Konica Minolta website, I can't see any drivers for Mac.
Check for yourself the link below:
http://printer.konicaminolta.com/support/current_printers/PP1400W_sup.htm
Top of words are cut off
Often times, some documents might have their margins or header/footers set to high for the printer to handle. Try opening the document and checking the margins, one inch all around is usually the default margin settings.
I dont have driver
I will give you a easiest way for finding the drivers that you need
foryour hardware.Just download the software named driver
magician.Installit and it will search for the drivers that is not
installed for thehardware you have through internet and will download
it for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
Blinking light
Switch OFF/ON the printer and continue printing.
It works for me.
Paper not going in
check the paper path, make sure the cassette spring bounce up went you load
