20 Most Recent
Thermador SEC301 Electric Single Oven Questions & Answers
Thermador SEC301BB broiler doesn't work
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
My Thermador RDDS30VRS only heats
If you have the use and care manual, check to see if your unit has the option to change from farenheit to celcius. If so, make sure yours was not accidentally changed to celcius.
Heating elements do not heat
it sounds as if you have a tripped thermal cut out. This is accessed by removing the 5 or so screws on the black grate below the control panel and pulling the grate out. Somewhere in the middle towrds the front should be a little button wiht 2 wires hooked to it. make sure you have the power off to the oven, then reach in with a screwdriver or your hand if you can and push the little red buttton down untill it clicks. The cause for this to trip could be bent door hinges not allowing the door to close fully (common thermadore problem), bad door gasket especially in combination with running a self clean cycle, broiling with the door ajar, or a bad cooling fan (the one behind the electronics, not the one in the oven) Hope this helps.
Heating Elements for oven and broiler do not heat
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
I have a Thermador CM302BS oven and it will beep just once about every 30 minutes. No lights are on or anything?
If your Thermador CM302BS oven is beeping once every 30 minutes without any visible indication on the control panel, it's possible that the oven is experiencing an error or malfunction that is not being properly displayed. Here are some steps you can take to troubleshoot the issue:
- Check the owner's manual: Consult the oven's owner's manual to see if there are any troubleshooting tips related to the beeping issue. Look for any error codes or messages that may be related to the beeping.
- Reset the oven: Try resetting the oven by turning off the circuit breaker that powers it, waiting a few minutes, and then turning the circuit breaker back on. This can sometimes clear up temporary issues with the oven's electronics.
- Check the oven's self-diagnostic system: The Thermador CM302BS oven has a self-diagnostic system that can be accessed by pressing a series of buttons on the control panel. Consult the owner's manual to see how to access the self-diagnostic system and check for any error codes or messages.
- Contact a repair technician: If you are unable to resolve the issue using the above steps, it's possible that there is a more serious issue with the oven's electronics that requires the attention of a qualified repair technician. Contact Thermador customer support or a local appliance repair service to schedule a service call.
It's important to address any issues with your oven promptly to ensure that it is operating safely and efficiently.
